New to me Model D Identify please |
Page 12> |
Author | ||
TurboTexas ![]() Bronze Level ![]() Joined: 15 Jan 2017 Location: New Berlin, TX Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jan 2017 at 10:07am |
I stumbled onto a Model D, and I'm not sure how to figure out what year engine etc.
I tried searching, but I kept getting rejected for the 3 letter minimum! Now I can't load photos from my iphone6+! Too large of a file size... Pretty lame I can't get any help here!! |
Sponsored Links | ||
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
You have to edit the size of your picture to shrink it down. On the left side there should be a serial# stampd on the flange where the engine bolts to the tranny/torque tube.
DonBC ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 904 |
If you are referring to a D Grader the serial number would be on a plate riveted to the frame where you climb onto the grader. The number should start with a 'D' followed by 4 numbers. Post these numbers and someone on this site can tell you the year.
Where can I find info on fluids, capacity and types?
I've already changed the engine oil! Looking for where you fill, where the levels need to be, what weight of lube for chain boxed and the tranny! |
You haven't said what you have yet. Is it a D grader or a D series tractor?
My apologies, it's a Model D grader |
Any suggestions on a .jpeg size reduced that works well with an iPhone??
This is no help! |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50865 |
Grille looks like the '52 D, in norm's construction book. It should have a wd 226 c.i.motor, either that or it could have a 201 from a wc if someone swapped one in. I'd take some gentle paint remover, to that aluminum tag, and use a scotch brite kitchen pad, and gently brush back the orange paint, to see if the stamped numbers are still there. Could be that some idiot sandblasted everything away, before that last orange hosing. There could also be a block number, up above the carb, on top of the block, near the VC gasket surface.
On second viewing pf the pix, it looks like a D special, with the leaning front wheels, power angle, etc. What size are the tires?
The tire size is 8.25 20 This has the power circle and yes the tires lean! |
Is there an online manual to these? I'm still needing to know what kind and capacities in the fluids department!
Or is there a way to search on here without the 3 letter block kicking in? |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8598 |
Looks like you have a real gem there, Turbo Texas. Looks sweet. Unfortunately, I won't be of any assistance to you on it, but be patient, and information will come. Like another said, try removing the paint from that serial number plate, and hopefully the serial number will show up. Traffic is a little slow here on the construction side of the forum, but some knowledgeable people will show up for you with the information that you need. Darrel
Frustrating that I can't find any info on a simple thing like fluid changes? |
Ages Cat ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 684 |
The wheel hubs appear to be (non-D Special) equipment. Grill is the late style grill usually used with the square tube machines.
Curt Anderson
HD3, HD5B, HD6E, HD6AG,HD6B dozer, I-400, 615, 616,620, 720, ACP25 lift truck, 1956 D Grader, AC 540 loader, 655 loader, AC #84 plow, Simplicity tractors, Agco MT225. |
Ross D. ![]() Silver Level ![]() ![]() Joined: 02 Sep 2013 Location: Erin, Ont. Points: 338 |
Hi. General information:
![]() Sorry, all my manuals are back at my shop in Ontario; or, I could look up some of the details that you are asking about. We are currently in Florida. Ross D. |
Thank you for the bit of history! Enjoy your warm winter! I'm from South Texas, and I grew up seeing "Snowbirds" come and go! I can't blame ya for wanting to get out of the cold!! |
Look for that number, on the head, it may be traceable, and may tell you if its a wd motor. If so, engine data will be the same as for a wd tractor engine, as far as specs and capacities. does it have power blade slide? If so, it is a d special, to spite what the decal by the seat says...
on edit: Looked at pix, again, no power blade slide, so its just a D...
I'm not sure what a power slide is?
The engine oil has been changed, with a 10/30 and Lucas oil stabilizer! Now I'd like to drop the fluids in the transmission, & the two chain boxes! I would also like to replace all the hydraulic fluid out to new! Just so I know everything's right! |
Hi again. Serial number location !
Ross. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78748 |
shrink to fit
I posted a photo... someone got carried away with the paint! :( |
I'd love to find the ripper attachment! |
powerslide allows you to move the blade about a foot to the left or right, hydraulic-ly...
Actually I believe it has that option? 5 total hand controls...
So what kind of oil do I put into the chain boxes?
Ian Beale ![]() Orange Level ![]() Joined: 03 Oct 2011 Location: New South Wales Points: 942 |
Well the AC 45 book says above 32 F SAE 50 engine oil
FWIW |
Dgrader ![]() Orange Level ![]() ![]() Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
I used 90 weight in the D we had.
Ya cain't fix stupid.
Page 12> |
