Ferd recalls
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 8:17am
YEP........ they ALL have their problems. EVERYTHING gets more complicated and harder to work on.. and the more complicated they get, the better chance of a recall to FIX something....I had a 1969 CHevy and a 1978 FORD and neither on got recalled for anything... Of course the "GUARANTEE" was good for about a month back then... and the NTSB didn't bother looking into too many " safety problems".... I have had FORD trucks since 1978 and very happy, even with the minor problems that come up.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 11:02am
I'm seriously looking at a 69 Chev C10 with 350 auto, but no box. Cab is in good shape, I think the box got abused?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 4:24pm
I stopped by the dealership I worked at yesterday and told the owner to get me a new pickup. He is getting me a new Dodge or Chevy, which ever he can get me by mid March. I bought liscense,plates for the ones I have yesterday. I found out the ferd my wife bought is 2 years newer than I thought, also found out it is a 450 dually not a 350. Doesn't make any difference, I can't find a dealer that wants to take it in trade.
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 5:10pm
We have two Ford dealers in the town closest to me and you can't get a used Superduty at either of them. They have waiting lists and as soon as one gets traded in or lease return it is gone.
But I hate dealers and trades anyway. Back in 2013 I went to trade my 2007 F350 in. It was mint. They offered me $11,000. Meanwhile they had 07's on their lots for $29,000.
Nothing like trying to make a buck. Overcharge you for the new one, and kill you on your old one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 5:17pm
That would be awesome! I've always been a Ford guy, but I wish I could have found something like that. Simple, reliable and cheap for parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 7:36pm
Tom...sell it to Les...he needs parts!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 1:37am
I think Ford is headed the way GM went because in the last 8-10 years they've produced a lot of junk. I really like the look of the newest Super Duty, but no way in he** I'll buy one. The 6.7 is fast becoming the 6.0 in problems caused by pure stupidity. Absolutely tiny valve stems that drop the heads off, the valve heads are so thin that they crack. The injector hold down bolts are too thin. If they don't snap off going down the road, they break off when you replace an injector. The hold downs themselves will break. They can't seem to install the vacuum pumps tight so they don't leak. Main water pumps are very common failures. Turbos are another common problem and it's not unusual to get a bad one right out of the box. 6mm bolts in the exhaust manifolds, what was someone thinking there? You'd think they would have learned their lesson on pulsing injectors in the exhaust stroke to regen the DPF with the 6.4. With no tabs on the main and rod bearings, along with the fuel that gets in the oil, spun bearings are another major problem. Then the problem we hate the most is the code from hell, P207F. Could be a NOX sensor, could be the complete aftertreatment system, could be half the whole truck. Once you do figure it out it's a pain in the a$$ just to get the 207F to clear.
The Ecoboost engine in the Fusion and Escape is bad about cracking heads, and they don't seem to be able to build a door latch that stays closed. The dual dry clutch in Fiesta and Focus shudders enough that Ford added a test in IDS to measure the shudder. If it doesn't exceed their predetermined value, it won't generate the code required to replace under warranty.
Then there's the lousy warranty times, so poor that there is a class action lawsuit against Ford for intentionally lowering the times to save on warranty cost instead of spending enough time on R&D.
Quality hasn't been Job 1 for quite a while now...
Edited by Brian Jasper co. Ia - 01 Jan 2019 at 1:38am
