Electronic cut out question
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Topic: Electronic cut out question
    Posted: 22 Jun 2011 at 4:33pm
I am wiring up my CA and have purchased an electronic cut out for the generator. I am wiring as original with 6 volt positive ground. My question is do you hook the + terminal on the cut out to the ammeter or the generator?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 4:38pm
terminal that says BAT on the cut out goes to the ammeter.  I just ran into this putting my CA back to 6Vpos. grd.  The "F"ield is varied by the resistor switch in the dash.  A short jumper wire runs from the GEN terminal of the cut out to the "A"rmature post.  hope this helps.   -Wes
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 4:46pm
Thanks Wes for the info!
Sam
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 7:23pm
Quick test. Take the fan belt off. Connect wires to cutout, battery, and generator. If the generator motors the cutout is backwards.
Gerald J.
