D17 steering leak
71cgrave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Topic: D17 steering leak
    Posted: 11 Mar 2025 at 10:03pm
Have a 1960 d17, it started leaking ps oil from underneath the radiator on top of tank. Between the front mount pump and the add on loader we can't see where from, any ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 10:18pm
If it happened all at once so to speak, I'd say it is leaking on the right side behind the grille shell. There are four tapered head allen bolts that sometimes loosen up with age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 7:57pm
Not leaking there. Had it parked downhill today and could watch it run across to top of oil tank on the left side looking at the front
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71cgrave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 7:59pm
Have to take the loader lose to get the side panel off
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 9:10pm
Best way to see it is to remove the shroud, maybe even the radiator if you still can’t see it. The fitting that the sump line attaches to is aluminum it may be cracked and leaking. NLA so I had a hydraulic shop make me a new fitting and hose connection. Works great.
Edited by AC720Man - 14 Mar 2025 at 9:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 9:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 10:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 10:18pm
A year and a half later and the new fitting still works great.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:52am
You did a great job on that 17!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:41pm
Thanks Mike. Almost a year worth of work to it and a lot of new parts. I do enjoy that tractor. I would be surprised if his leak isn’t with the original fitting.
Edited by AC720Man - Yesterday at 6:42pm
