D-17 Final Drive oil change.
KY D-17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY D-17 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Final Drive oil change.
    Posted: Yesterday at 9:37am
How do you drain the oil form the final drive to change it on a D-17 Series IV?  KY D-17
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:27am
remove the pan. might be easier if wheel is shifted out
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY D-17 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:34am
Do you need new gaskets?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:38am
Likely. Won't know till dissasembly
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:58am
I replaced the oil in the final drives on my D-17 a few years ago.
Dropped the pans and made new gaskets.
I did have the wheels moved out.
I chose to fill the pans before installing them but you could fill thru the fill plug as well.
Not a big job.
Edited by Brian G. NY - Yesterday at 11:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:54pm
I changed mine 2 years ago, according to the smell it was the original oil. Really stunk. New gaskets and put a clear hose attached to the oil bottle and refilled through the filler hole until it was to that level.
Edited by AC720Man - 14 hours 24 minutes ago at 6:47am
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:09pm
I did what Bryan did on my WD a few years back. Just make sure if you prefill the pan that you don't overdo it because the bull gear displaces a lot of oil in that pan as you put the pan back into place!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY D-17 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:53pm
Thank You
