CA question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: CA question
    Posted: 21 Jun 2016 at 4:14pm
I drained the trans & diff refilled with diesel as a flush. Tied the clutch down and put trams in gear so it will turn as I roll the tractor. My question is will the pump turn therefore flushing it too, as the tractor moves, if it is engaged.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 4:43pm
If you mean the hydraulic pump; it only turns when the PTO is engaged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 4:58pm
Yes I am referring to the hydraulic pump, the tractor doesn't run so will the hydraulic pump turn if the tractor is towed with the pto engaged?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 5:02pm
Yes it should run the pump.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 5:06pm
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 5:25pm
Thanks
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 9:16pm
When you drained the oil did you remove the drain plug in the PTO?  If not there may be some residual oil there.  There is a dam that keeps the oil from "running away" from the hyd if the tractor is going down hill or overfilling if the tractor is going uphill.
If the PTO plug was not pulled I would suggest that it be pulled and the PTO drained then check the oil level in case more oil is needed.
I wish you luck with the use of diesel oil to clean.  If it does not work then you will have to drain the PTO oil and remove the pump for a good cleaning.
Let us know how it goes.
Good Luck!
Bill Long
Edited by Bill Long - 21 Jun 2016 at 9:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 5:14pm
I removed 2 plugs, 1 under the PTO and 1 above and in front of the pin hitch. Are there more? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 7:24pm
Good Job!!
Most forget the PTO drain.  There is also a small one in the bottom of the linkage of the hyd pump.  Not much oil there
Good Luck!
Bill Long
ps:  Sorry I forgot it
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 8:03pm
I've got a couple gallons of diesel fuel in, the pto engaged, tractor in gear with clutch tied down, and lift lever up, so I roll it 8 or 10 ft forward and back a few times a day, until grandson comes over and he can steer while I tow him up the street. Will drain and replace with transfluid before starting.
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 6:30am
i'm missing something here......with the clutch pushed in, the pto does not run on a CA......???
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 6:38am
The clutch connects the engine to the transmission for the engine to operate the tranny which runs the PTO and hydraulics thru the tranny. With the clutch disengaged, turning the wheels will turn the transmission over driving the PTO and hyd pump.
Edited by CTuckerNWIL - 23 Jun 2016 at 6:39am
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 6:40am
Not if you are running the Tranny/PTO with the engine, but if you are rolling the tractor with the tranny in gear it will. In other words, he is using the wheels to turn the transmission, without it turning the engine over. That is why he has the clutch pushed in.
'39 Model B
Tractors are cheaper than girls, remember that!
SteveC (NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC (NS) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 6:45am
Alan, if he's talking about the "foot clutch" the only "drive" that is disconnected is between the engine and the transmission. If he means the "hand clutch" then nothing in the transmission, including the pump and the engine will turn when the tractor is pushed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 9:12am
ok... next time i won't read and sleep at the same time.....knew i was missing something...
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 9:46pm
The clutch is depressed and he is rolling and towing the tractor in gear.
The gears and the PTO will turn. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 6:41pm
So I was rolling CA back forth today, and I noticed the lift arms were up, so placed lift lever in down position and pushed arms down, moved lift lever back to up rolled forward and back a couple of times lift arms went back up. I believe lift will work really good when I get tractor running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 6:55pm
  Thumbs Up
This page was generated in 0.134 seconds.
