bolting carb to new manifold on my wd |
Jaybird14
Topic: bolting carb to new manifold on my wdPosted: 23 Jun 2020 at 8:33pm |
I just got a new manifold for my 51 wd. it is a bit different from what is on there. I have a Zenith carb and there is not enough room to get the bolts between the top of the intake flange and the body of the manifold. the flange is so thick even with shorter bolts i dont know if there will be enough threads left to hold the carb on. Whats the solution??
Thanks!! Jay
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2072 |
Posted: 23 Jun 2020 at 9:03pm |
You will most likely have to put studs in the carb and then you will be able to put them up thru the manifold with nuts on top of the flange. Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54426 |
Posted: 23 Jun 2020 at 9:07pm |
Or thread the manifold and install studs in it...
Jaybird14
Posted: 23 Jun 2020 at 9:09pm |
Thanks Den,
That's not the worst thing . It looks like 1/4 - 20 ?? The casting was kind of poor, i have already filed casting "flash" off the top of the flange. I thought this would be a quick swap... lol.
Edited by Jaybird14 - 23 Jun 2020 at 9:15pm |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 24 Jun 2020 at 5:06pm |
Jay, nothing simple is ever easy. And the corollary is also true: nothing easy is ever simple.
Dave
WC, CA, D14, WD45
twinsonfarm
Posted: 24 Jun 2020 at 5:26pm |
Poor casting, I got a couple like that, I sent them back. Total junk, they were made in turkey if I remember correctly. Got one from Steiner that was good to go. All States Ag were the bad ones.
Jaybird14
Posted: 24 Jun 2020 at 9:05pm |
mine is from Steiner. who the heck designed it so the flange is too close.
i still need to file the neck above the flange so the nut can spin on the stud i made. |
twinsonfarm
Posted: 24 Jun 2020 at 9:37pm |
The sand casting was just not correct when manufactured.
Jaybird14
Posted: 24 Jun 2020 at 10:28pm |
a little quality control would be a huge deal. I'll get it done lol.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 25 Jun 2020 at 12:07pm |
The parts books shows a stud in the carburetor. PN 70230917. I think is 5/16. Fine thd. one end, course on the other. Should be able to get at any auto supply.
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 25 Jun 2020 at 5:52pm |
There supposed to be a stud both ends set the nut on the flange and screw the stud up into the nut then put your gasket and carb on with two more nuts the neck usually holds the top from turning thighten from the bottom. Threading wont work due to 5/16 Hole you would need tothread the manifold 3/8 then drill the carb 3/8 and think it would be to close to turn a bolt or nut
Jaybird14
Posted: 25 Jun 2020 at 9:08pm |
5/16 course thread screws nice into my carb.
I've cut two little threaded rods, screwed them into the carb, slid the stud carb combo partially onto the manifold flange. just far enough to get the nut started. tightened it all up. after a pile of filing and cutting two studs all fits. lock tight will be a must. i will start painting this weekend. |
