B side weights |
DaveWisc. ![]() Orange Level ![]() ![]() Joined: 11 Oct 2009 Location: Wisc. Points: 1008 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Nov 2017 at 3:30pm |
Do the weights that bolt on the side of the engine have a spacer on the inside of the bolt or not. I am in the mode of buying weights and want to know how they are mounted. Thanks Dave
Hubnut ![]() Orange Level ![]() ![]() Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Dave,
I don't have my parts book handy, but there is a bolt that goes through the front engine plate. That bolt holds a fitting of larger diameter that the front of the weight slides into this. I've used a pipe if you can't find the fitting. Steve |
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5890 |
Like hubnut says for the front: hex head bolt, lock washer, and spacer. At the rear: hex head bolt and lockwasher. |
