Allis Chalmers 5040 Clutch
lkennett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lkennett Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 5040 Clutch
    Posted: 25 Aug 2025 at 2:40pm
Hi guys, I have a new to me 1976 5040.  6 speed with the dual clutch.  The clutch has been slipping badly (known problem when I picked it up)  I have the inspection plate removed after taking the loader frame off.
Anything in high range is completely useless.   When I take the inspection plate off the first thing I notice is alot of grease.  Second thing is the clutch fingers are touching the throw out bearing (I think there should be a gap).    Does anybody have access to the clutch specs.  How to adjust?  Basically pages from the service manual.
I am about a day from splitting the tractor, I only have the fuel linkage and a hydraulic line to disconnect and I can start.   I expect once I get it apart it probably needs a whole clutch kit and flywheel machined but I would like to verify if I knew the tolerances.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 8:07pm
Not familiar with those but My guess is someone over greased the throwout bearing? Assuming that’s what the grease zirk is for. Hopefully Gary Burnett will see the thread, he knows these tractors well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lkennett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 9:17pm
I have never had a tractor with a greaseable throw out bearing.  Nice feature but don't over do it I would think.   My dad just had to have the throw out bearing done for the second time on his Case 685.  $$$ to have a shop involved.  He wishes it was greaseable!.
Lots of mysteries with this 5040.  Unknown hours.   The previous owner said it was a loader tractor used in the hay field.   He is an older guy that seems to buy and sell alot of equipment.   He was using the loader and noticed the transmission was overflowing with fluid.  The seal on the loader pump let go (I posted previously) and was dumping into the trans.   I said is it possible a bunch of fluid got dumped into the clutch area?  It just feels like nothing is there.  I can pop the clutch in 3rd low and the tractor just starts to walk forward.  High range 4th it wont even move unless i am downhill.  No smells, no smoking.
I only have to disconnect the main hydraulic return line and I can have it split tomorrow or the next day.
It would be nice if I took this apart and it just needed a clutch disc and not the whole kit.  I am in Canada, probably looking at $1500 for the parts at least.
Lawrence
Post Options Post Options   Thanks (0) Thanks(0)   Quote lkennett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 9:02pm
Split the tractor tonight.  Not dusty but greasy!  seems like alot of oil.  I had a half can of brake clean but I will run to town tomorrow and get a couple more cans.   Just so much to clean up.   The driven clutch is toast.  PTO clutch looks fine.  Throw out bearing and Pilot bearing also look fine.   I am not sure about the rest of it.  If anybody has specs it would be appreciated.  Trying to figure out next steps.   Here are some pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 14 minutes ago at 6:33pm
Wow- it is toasted,, Everything can be redone- gotta find the source of the contamiante,, might as well put a new rear main seal , and every seal thats in there
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 49 minutes ago at 1:58am
If it was mine I'd get an all new already set up clutch pack and with new PTO disc,plus new release bearings.Redid my Oliver 1365 4WD a few years ago,same basic set up used all new parts.Putting old parts against news ones in those units doesn't work out well most times.
