Allis 7050 will not move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 10:06am
Proper seating of the torque limiter isn't by releasing the clutch pedal. It is done with the tractor already in motion at full throttle in 2 or 3rd gear high range and then stand hard on the wheel brakes. This is a shock load and will allow the torque limiter disc to slip and center itself.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 11:10am
Huh! I wonder / hope the mechanic that had mine apart a few years back knew about this. He never said anything to me, so either he did it himself (sorta doubt it) or he didn't know. Did I get extremely lucky? Is it too late to do any good now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 12:09pm
If they're not centered, they don't last very long at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 12:16pm
He must have done it then. It's been probably 4 1/2 years, 300 hours.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 2:11pm
Sometimes you can be lucky by not doing the centring/slipping procedure on the torque limiter.
I've done a couple and have not done it. (I didn't know)
I plow and use a deep tillage cultivator, so by putting it in deep and making the tractor pull hard, it can center.
I wouldn't worry about it after 4 + years.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 4:06pm
Man I work way way to cheap and then I feel guilty sometimes !
turbocharged
Blue Yonder Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue Yonder Farm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:21pm
Anyone want a two week work vacation to Northern Wyoming? Work in a heated shop on a 7050 AC. Come hunting Mule Deer with us. Help butcher a pig. Work on our tractor. Send home some deer that my family harvests (sorry you can not do the harvesting but can watch us!), hog, maybe a lamb in freezer boxes. Plus rate some cold hard cash in your pocket home....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:39pm
Wow!
Sounds like a great working vacation! Someone on here might just take you up on that!
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:45pm
Back in the seventies I put a disc in without removing the cab. We took the AC compressor off and left all lines hooked up, we put all AC components on the steps. If you have front weights, take them off, you will not be happy if you don't.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:52pm
When do you need it done?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue Yonder Farm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 7:16pm
I will talk with the Banker Spouse
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 9:31pm
Always good to consult with the bank first Wink
Man! A heated shop........ that makes it almost too easy! Wish mine was.....would have made all my splitting experiences a LOT more plesant.
I would totally be down for helping if only my Scheduler Spouse would allow it LOL
~Warren
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 11:17pm
Don't know how a 7000 series compares but I had to pull the tranny out of my 8070 and supported the front of cab with lengths of 1 1/2 pipe with 1in redi-rod and some nuts and washers to make a crude screw adjustable "jack".The A/C stuff was unbolted and tied/laid in cab.When I split it later to fix the leaking rear main I don't remember having to do anything to the cab.Maybe they are made different?
   I don't remember if the book gave guidance on removing the PD but it is HEAVY!!!!! and back in a hole so theres no good way to get hold it.I had access to a truck transmission jack(heavy) and made a bracket on it to pull/install the PD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 2:20pm
I've pulled dozens of them out over the years.....by hand. Have a bench very close by to lay it down on. Probably 150 lbs ??
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 8:24pm
I had a 7030, stopprd to adjust disc, back in tractor and would not move.  Had splines gone off a shaft but don, tremember which one.  Had it apart a couple times for power directer work and the shaft and never removed the cab, local dealer did it and did several that way.
