A-C 160 project
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: A-C 160 project
    Posted: 30 Jan 2026 at 4:24pm
Working on a 160 to get it back up to snuff.
Has a bunch of leaks and it pops out of 5th and 6th gear going down hill. Not too worried about fixing leaks as the popping out of gear could mean an impossible search for gears.
Parts seem to be kinda hard to find for those tractors…
Thinking it’s an early model from looking at it.
Haven’t dug into the trany yet due to weather being cold and no heated nor insulated shop but next week looks promising.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2026 at 5:18pm
we stock the rubber shifter boot, and can get some 160 parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2026 at 5:34pm
Local agco said they got one…
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2026 at 8:49pm
Unfortunately these 160’s/One-sixties are hard to get parts for. Great little tractor though
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 10:09pm
Is it a letter tractor or a number tractor? One-Sixty or 160. Letter tractor is the early model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 46 minutes ago at 10:26am
It’s an One-Sixty so it’s an early one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 58 minutes ago at 9:14pm
May be able to find a parts tractor in your area. I found one in Ga that I got the 2nd set of hydraulic remote parts off of to add to my 160. Wanted 4 remotes to run our tedder. Just takes time and research to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 51 minutes ago at 10:21pm
I think have some shift forks and gears available
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 30 minutes ago at 10:42pm
That would be nice to have a parts source near by!!
Is the transmissions the same on the early ones vs the later ones?
Still not sure on the gear popping out problem so I’d would like to see it do it but it’s been too cold out to run it.
The wiring is kinda concerning me with the cracks in the insulation, showing bare copper so I’m thinking on a new wiring harness if they are available.
Sounds like towards the end of the week will be good weather so maybe I can dig in on it.
