8550 Shift cables
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: 8550 Shift cables
    Posted: 11 hours 10 minutes ago at 1:28pm
Been a very long time since my last post, but here goes.
Thought I'd get my 8550 fired up for the first time in a few (too many) years. Started right up and sounds good BUT I think my shift cables are seized up from sitting. I can get it into neutral (it easily towed a few feet) but the range lever has limited movement forward and back. Similarly, the gear lever won't go into any gear (but will turn as it should).
Has anyone got experience in freeing up the cables. I'm pretty sure its frozen cables.
Secondly, is there a source for new cables out there, in the event option one doesn't work. The tractor is well worth fixing, has low hours and is in fine condition.... except for the above problem.
Would sure appreciate any help fixing or sourcing my shift cable problem.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 17 minutes ago at 4:21pm
Bunker Hill cables is where I’d look
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 16 minutes ago at 4:22pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 55 minutes ago at 5:43pm
The range shift and park lock are done with cables. The actual gear shift has linkage and rods. The gear shift twisting part does use a cable. Probably dry and needs lube on the gear shift parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 48 minutes ago at 6:50pm
Probably available from AGCO. They are costly
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 13 minutes ago at 9:25pm
I'd go with Bunker Hill cables. I got replacement shift cable for our 8550 there.  Andy
dp7000 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 46 minutes ago at 9:52pm
Bunker Hill if you need cables. I’d spray penetrating oil everywhere I could get to first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 25 minutes ago at 11:13pm
If you're going to try and lubricate the cables, try this. From the cab end of the cable, disconnect it and point the end "up" somehow. Remove any hardware from the end of the cable. Peel back/remove the rubber dust seal from the end. Slide a 5/16" or 3/8" gas line hose a foot long (or more) onto the cable and secure it with a hose clamp in the cable anchoring area. Now jury rig some sort of small funnel at the end of the hose pointing up and fill it with diesel fuel or penetrating oil and leave it sit for a week or more, keeping it full of fluid. There's no other way to get lube inside that cable and hopefully this will get it there.
