8000 steering motor???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 8000 steering motor???
    Posted: 14 Apr 2019 at 11:56am
Have a leak up in the steering some where's. What's the best way to get in there. Through the dash or through the panel behind engine. Just thought I'd ask people that have done it before. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 12:48pm
Engine bay...nothing behind dash..put new shaft seal in my oozer.time cosuming but not hard
Edited by SteveM C/IL - 14 Apr 2019 at 12:50pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 1:08pm
Side hoods off,cookie sheet behind engine off,three metric bolts out(17mm socket I think). I don't think you need to even take the hoses off. Swing the steering valve out to get at the spiral ring that holds the end cap and seal. Best to use the Agco seal kit,it uses some Teflon pieces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 3:16pm
Ok thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 6:48pm
Looking at parts book see there's seal kit and bearing kit, is it common for bearings to go bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 7:35pm
No. Is extremely rare for anything else to leak except at the splined end cap. No need to take the rest of the valve body apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 7:38pm
Ok sounds good, thanks
This page was generated in 0.227 seconds.
