7000 seat shock
dp7000 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 seat shock
    Posted: 07 Jul 2026 at 10:23pm
Hello folks, I need to replace the spring/shock on the seat of my 7000. I bought one from DJs along with bushings.
Should I try to replace with seat in the cab or remove seat assembly? I’m a big old guy so it’s tight and I’m not as flexible as I used to be. Any tips would be greatly appreciated. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2026 at 10:49pm
Get it out of the cab.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2026 at 11:20pm
Thanks for your reply Doc.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2026 at 12:19am
I did mine last year and started off trying to take it apart in the cab, but soon found it was easier removed. If you take the seat off the suspension it is a little less cumbersome. Some bolts are easier to get to standing on the drawbar and reaching through the rear window. I swapped my pivot pins front to rear because they wear in different locations. I took some pictures of the process, more for me to remember than anything. It is well worth the effort.
https://photos.app.goo.gl/q1kdkt5MJpBgr9Dg8
The comment in the album is a little more detail on the process.
Ted
Edited by TedN - 08 Jul 2026 at 12:26am
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2026 at 5:33pm
Thanks Ted for the pictures and comments. I haven’t started on mine yet but the information you shared makes a big difference. Will update when I get to it. Hopefully tomorrow.
Edited by dp7000 - 08 Jul 2026 at 5:34pm
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2026 at 6:42pm
One other note on this, mid project is when I decided I should get an electric ratchet.
Ted
8070nc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2026 at 7:15pm
Ted thats a good looking seat. Did you have the original recovered or buy a new on. If its new where did you get it?
Thanks
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2026 at 7:39pm
I purchased it new from Vevor. I haven't been in the tractor much since I changed it, but it came with rails to adjust forward and back. They don't slide because the bolts hit, and they add a little too much height. I need to remove them, just haven't got to it yet. It also has another pad to go on top, but I run a baler so I thought it might get in the way. Second cutting is coming, I will get the rails out and maybe try the headrest.
Ted
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 7:30pm
Well, finished my seat rebuild. Thanks to Doc and Ted. Pictures and comments were especially helpful. I wouldn’t say it’s an easy job. But well worth it. Feels like a different tractor not flopping back side to side. And new shock doesn’t bottom out like before. Ted is right, recommending power ratchet. And it helps a lot to have a partner inside the cab to keep a wrench on the bolts when removing the seat frame. My lovely little wife of 40 years helped me. As always thanks to forum members for your help. dp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 8:20pm
I cannot stand a seat with sloppy suspension and a shock that bottoms out when I did down on it.
