170 ALLIS temp gauge
andrewj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewj Quote  Post ReplyReply Direct Link To This Post Topic: 170 ALLIS temp gauge
    Posted: 15 Apr 2022 at 9:08pm
So i have a new temp gauge , sender and thermostat all from AGCO...the gauge is reading all the way to the end of the red on the new gauge..12 volt supply.
Does anyone know what ohms range the sender should be?
I put a temp gun on the thermostat and its 180 F ..my NEW gauge reads way to high for the temp its at..and ideas would be helpful..thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 9:23pm
Not sure what the ohms reading should be but I think you may not have a good ground between the 2. That was my issue on my XT
JC-WI View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 10:16pm
make sure the tank and the gauge are grounded  good.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 6:28am
old gauge has 2 post .new gauge has 3 post 3rd post is for a ground wire witch you can run to gauge panel .Then your new gauge will stabilize .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 6:38am
What Fred said. You need a third (ground ) wire to the gauge.
