New Years Day Project |
Post Reply | Page 12> |
Author | ||
Bradleytrench
Silver Level Joined: 12 Mar 2013 Location: Missouri Points: 137 |
Posted: 01 Jan 2019 at 6:20pm |
Todays adventure was to get the rusted out floor pan out of my newly acquired 14ft A2 head. Tomorrow I will call and see of i can get a new floor or if i will have to make one. |
Sponsored Links | ||
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8030 |
Priced one from AGCO a few years ago for my 15ft F2.....had doubled in a couple years....was around 1500 but available !!!.Thinking the plastic liner made more sense...not cheap either.
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
Looks like a heck of a way to cure a hangover.
Bradleytrench
Thanks Albert up at Maryville MO, i have found a NOS floor for my head. The price was very reasonable. Just have to make the trip halfway across KS to get it.
I have the trucking handle. Have a load going to salina. |
Don(MO)
Orange Level Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Bob has a fully equipped sheet medal shop with the tin in the bins but at the price he found a NOS pan it was faster to put in the new pan and will save hours of time punching all the holes in a shop built pan. Sometimes is less money in the long run to buy a new factory part over aftermarket or even a used one.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21549 |
just curious ,but could you use one of those 'bed liner' products to protect the tin ?
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11399 |
would have to be of the "slippery" kind
Don(MO)
I think Bob is headed West to get the new pan so it might be here Sat morning. I have not seen the lower pans in Bob's last pic before I'm thinking they are not factory, have you guys seen them before?
Bradleytrench
Today has been busy. Moved a couple of containers this morning. Went to dads and started on putting the head back together. Cleaned up all weld on garbage. Clecoed in the NOS floor pan. I used some modern technology. I wasnt in the mood to buck 110 rivets. Since i have access to a huck bolt gun, i hucked the floor in. Put the guards, and what new sickle sections I had. Im also updating to bolt on sections. No more rivets. Next step is the auger. The bearings are froze up in it. Bobby (MO) Edited by Bradleytrench - 09 Feb 2019 at 10:17pm |
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
huck bolt gun?
Bradleytrench
Huck bolts are mix between a rivet and a bolt. The stem on the bolt is scearated stem on it. You put a huck lock on the stem. The nose of the gun is designed to crush the huck lock to the scearated stem on the bolt. They use them to assemble Paccar cabs. The huck bolts dont come loose. Bobby (MO)
Ranse
Orange Level Joined: 11 Mar 2016 Location: Tennessee Points: 773 |
I used to work for Carrier Air Conditioners. We used a huck bolt gun to fasten frame rails together. Once you put something together with one the only way to get it apart is cut it. I hadn't seen one of them before or since those Carrier days.
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5502 |
You have done some real nice work there. Oh how the floor pan is going to shine after them soybean stems work it over. Keep the pictures coming.
Don(MO)
Bobby is going to rebuild his "AII" back to new as he can with mostly new AC parts. This is going to be the nicest 1967 combine around!!
Bradleytrench
Took the auger apart and the finger crank shaft is worn bad. Looks like the grease worms have been in the bearings. AGCO wanted $150 for a NOS. Went to a local weld shop found a piece of 1 in shaft. Went out to the farm and broached a keyway in the end. Welded the other end on it. More pictures to come. |
Bradleytrench
Made some progress today. All new bearings in the auger. Installed auger in the head.
https://youtu.be/3RfQQpyb0gg Next part is rebuilding the reel. Edited by Bradleytrench - 24 Feb 2019 at 11:48am |
Bradleytrench
Dad called me today to tell me more Christmas packaged showed up from Zieglar Ag. Albert sent the rest of my sickle sections. Filled the sickle and adjusted it. Put the reel on. Had to put just 1 bat and 4 new spindles on. Decided to call it a night. Bobby Mo |
1 WD45D, 1 A2 GLEANER, Wd w 33mounted corn picker
Don(MO)
This is what I call a true re-fit! Bobby knew he was going to spent lot's of time and money to rebuild, refit, restore, renew or what ever someone might call it and I'm happy to see him doing it right just like he go's at all the work Bobby turns out.
Bradleytrench
Ive got some good help today. My son decided to come help me.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33658 |
Thanks(1)
Very nice work being performed there. I have looked for a straight cut head for my F, and seems none to be found... most heads are for beans. [TUBE]3RfQQpyb0gg[/TUBE]
DennisA (IL)
Orange Level Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
Thanks(1)
Looking great!
Thanks & God Bless
Dennis |
Bradleytrench
New sickle drive head, tie tod end. Replaced the bearings with NOS in the wabble arm. New tired on sickle drive. Took awhile to get adjusting nuts freed up. Heat, taps and dies. New yokes, bearing holder, bearing, and snsp rings on sickle drive. NOS belts. Reel tensioner freed up. New idler pulleys on the reel belt tendioner. New drive gears from agco where $100. I went and got new weld on gears for $12. Cut the old gears off the hub. Replaced the gears. Cleaned up the shaft. New bearings. Replaced the adjuster bolt on the auger drive belt adjuster. Had several broken bolts the get out. Its been a day. Bobby MO Edited by Bradleytrench - 16 Mar 2019 at 7:42pm |
Bradleytrench
I know there is a pile of them in Buhler KS. Mikes Equipment has acres of combines. And 12 old turkey barns full of parts. You just have to get out in wheat country. Bobby MO
Unit3
Thanks(1)
You are going to a lot of work. It must be fun for you to have your son help with it. Just think how big the smiles will be the day this header goes "Back To The Field".
Bradleytrench
Thank you sir. This has been a project. Its fun when you have had 3 generations working on trying to save a piece of history. Not to many functioning A gleaner left. Bobby MO
polarbear
Silver Level Joined: 05 Jul 2016 Location: addieville il Points: 331 |
That is well illustrated great and real interesting
THANKYOU |
Bradleytrench
Kids wanted to go out to dads this afternoon to play in the creek. While the kids played, I put all the new spindles in, and 3 new bats on the reel. I straightened 2 of the bats. Replaced all the hardware that holds all the spindles and bats on. Started to put the anti wraps on the ends. Im hoping by next weekend, I'll have the head on the combine. Thanks for all the positive comments. Bobby MO |
SteveM C/IL
Class 8 trucks and trailers have been using huck bolts on suspension and frame members for many years now.
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
Hucks are an aircraft fastener. Kenworth uses them in pretty much everything. Like everyone said, once together they hold tight |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Bradleytrench
Before After Next project header trailer Bobby Mo |
