New Years Day Project
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=156871
Printed Date: 06 Jun 2024 at 8:16am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: New Years Day Project
Posted By: Bradleytrench
Subject: New Years Day Project
Date Posted: 01 Jan 2019 at 6:20pm
Todays adventure was to get the rusted out floor pan out of my newly acquired 14ft A2 head. Tomorrow I will call and see of i can get a new floor or if i will have to make one.
Posted By: SteveM C/IL
Date Posted: 01 Jan 2019 at 10:43pm
Priced one from AGCO a few years ago for my 15ft F2.....had doubled in a couple years....was around 1500 but available !!!.Thinking the plastic liner made more sense...not cheap either.
Posted By: wekracer
Date Posted: 02 Jan 2019 at 5:53am
Looks like a heck of a way to cure a hangover.
Date Posted: 02 Jan 2019 at 7:54pm
Thanks Albert up at Maryville MO, i have found a NOS floor for my head. The price was very reasonable. Just have to make the trip halfway across KS to get it.
I have the trucking handle. Have a load going to salina.
Posted By: Don(MO)
Date Posted: 03 Jan 2019 at 8:34am
Bob has a fully equipped sheet medal shop with the tin in the bins but at the price he found a NOS pan it was faster to put in the new pan and will save hours of time punching all the holes in a shop built pan. Sometimes is less money in the long run to buy a new factory part over aftermarket or even a used one.
------------- 3 WD45's with power steering,G,D15 fork lift,D19, W-Speed Patrol, "A" Gleaner with a 330 corn head,"66" combine,roto-baler, and lots of Snap Coupler implements to make them work for their keep.
Posted By: jaybmiller
Date Posted: 03 Jan 2019 at 9:36am
just curious ,but could you use one of those 'bed liner' products to protect the tin ?
------------- 3 D-14s,A-C forklift, B-112 Kubota BX23S lil' TOOT( The Other Orange Tractor)
Posted By: Tbone95
Date Posted: 03 Jan 2019 at 9:40am
would have to be of the "slippery" kind
Posted By: Don(MO)
Date Posted: 04 Jan 2019 at 7:25am
I think Bob is headed West to get the new pan so it might be here Sat morning. I have not seen the lower pans in Bob's last pic before I'm thinking they are not factory, have you guys seen them before?
Date Posted: 09 Feb 2019 at 10:13pm
Today has been busy. Moved a couple of containers this morning. Went to dads and started on putting the head back together. Cleaned up all weld on garbage. Clecoed in the NOS floor pan. I used some modern technology. I wasnt in the mood to buck 110 rivets. Since i have access to a huck bolt gun, i hucked the floor in. Put the guards, and what new sickle sections I had. Im also updating to bolt on sections. No more rivets. Next step is the auger. The bearings are froze up in it.
Bobby (MO)
Posted By: shameless dude
Date Posted: 09 Feb 2019 at 10:55pm
Date Posted: 09 Feb 2019 at 11:27pm
Huck bolts are mix between a rivet and a bolt. The stem on the bolt is scearated stem on it. You put a huck lock on the stem. The nose of the gun is designed to crush the huck lock to the scearated stem on the bolt. They use them to assemble Paccar cabs. The huck bolts dont come loose. Bobby (MO)
Posted By: Ranse
Date Posted: 10 Feb 2019 at 7:59pm
I used to work for Carrier Air Conditioners. We used a huck bolt gun to fasten frame rails together. Once you put something together with one the only way to get it apart is cut it. I hadn't seen one of them before or since those Carrier days.
Posted By: Unit3
Date Posted: 11 Feb 2019 at 8:37am
You have done some real nice work there. Oh how the floor pan is going to shine after them soybean stems work it over. Keep the pictures coming.
------------- 2-8070FWA PS/8050PS/7080/7045PS/200/D15-II/2-WD45/WD/3-WC/UC/C
Posted By: Don(MO)
Date Posted: 13 Feb 2019 at 5:39pm
Bobby is going to rebuild his "AII" back to new as he can with mostly new AC parts. This is going to be the nicest 1967 combine around!!
Date Posted: 20 Feb 2019 at 12:38pm
Took the auger apart and the finger crank shaft is worn bad. Looks like the grease worms have been in the bearings.
AGCO wanted $150 for a NOS.
Went to a local weld shop found a piece of 1 in shaft.
Went out to the farm and broached a keyway in the end. Welded the other end on it. More pictures to come.
Date Posted: 24 Feb 2019 at 11:46am
Made some progress today. All new bearings in the auger. Installed auger in the head.
https://youtu.be/3RfQQpyb0gg" rel="nofollow - https://youtu.be/3RfQQpyb0gg
Next part is rebuilding the reel.
Date Posted: 26 Feb 2019 at 7:43pm
Dad called me today to tell me more Christmas packaged showed up from Zieglar Ag. Albert sent the rest of my sickle sections. Filled the sickle and adjusted it. Put the reel on. Had to put just 1 bat and 4 new spindles on. Decided to call it a night. Bobby Mo
------------- 1 WD45D, 1 A2 GLEANER, Wd w 33mounted corn picker
Posted By: Don(MO)
Date Posted: 27 Feb 2019 at 8:30am
This is what I call a true re-fit! Bobby knew he was going to spent lot's of time and money to rebuild, refit, restore, renew or what ever someone might call it and I'm happy to see him doing it right just like he go's at all the work Bobby turns out.
Date Posted: 16 Mar 2019 at 1:38pm
Ive got some good help today. My son decided to come help me.
Posted By: JC-WI
Date Posted: 16 Mar 2019 at 4:30pm
Very nice work being performed there.
I have looked for a straight cut head for my F, and seems none to be found... most heads are for beans.
[TUBE]3RfQQpyb0gg[/TUBE]
------------- He who says there is no evil has already deceived himself The truth is the truth, sugar coated or not. Trawler II says, "Remember that."
Posted By: DennisA (IL)
Date Posted: 16 Mar 2019 at 5:25pm
Looking great!
------------- Thanks & God Bless
Dennis
Date Posted: 16 Mar 2019 at 7:36pm
New sickle drive head, tie tod end.
Replaced the bearings with NOS in the wabble arm. New tired on sickle drive. Took awhile to get adjusting nuts freed up. Heat, taps and dies.
New yokes, bearing holder, bearing, and snsp rings on sickle drive. NOS belts. Reel tensioner freed up. New idler pulleys on the reel belt tendioner.
New drive gears from agco where $100. I went and got new weld on gears for $12. Cut the old gears off the hub. Replaced the gears. Cleaned up the shaft. New bearings. Replaced the adjuster bolt on the auger drive belt adjuster. Had several broken bolts the get out. Its been a day. Bobby MO
Date Posted: 16 Mar 2019 at 7:45pm
I know there is a pile of them in Buhler KS. Mikes Equipment has acres of combines. And 12 old turkey barns full of parts. You just have to get out in wheat country. Bobby MO
Posted By: Unit3
Date Posted: 16 Mar 2019 at 10:17pm
You are going to a lot of work. It must be fun for you to have your son help with it. Just think how big the smiles will be the day this header goes "Back To The Field".
Date Posted: 17 Mar 2019 at 9:36am
Unit3 wrote:
You are going to a lot of work. It must be fun for you to have your son help with it. Just think how big the smiles will be the day this header goes "Back To The Field". |
Thank you sir. This has been a project. Its fun when you have had 3 generations working on trying to save a piece of history. Not to many functioning A gleaner left. Bobby MO
Posted By: polarbear
Date Posted: 17 Mar 2019 at 1:04pm
That is well illustrated great and real interesting THANKYOU
Date Posted: 17 Mar 2019 at 8:31pm
Kids wanted to go out to dads this afternoon to play in the creek. While the kids played, I put all the new spindles in, and 3 new bats on the reel. I straightened 2 of the bats. Replaced all the hardware that holds all the spindles and bats on.
Started to put the anti wraps on the ends. Im hoping by next weekend, I'll have the head on the combine. Thanks for all the positive comments. Bobby MO
Date Posted: 17 Mar 2019 at 9:19pm
Ranse wrote:
I used to work for Carrier Air Conditioners. We used a huck bolt gun to fasten frame rails together. Once you put something together with one the only way to get it apart is cut it. I hadn't seen one of them before or since those Carrier days. |
Class 8 trucks and trailers have been using huck bolts on suspension and frame members for many years now.
Posted By: DonDittmar
Date Posted: 18 Mar 2019 at 8:24pm
SteveM C/IL wrote:
Class 8 trucks and trailers have been using huck bolts on suspension and frame members for many years now. |
Hucks are an aircraft fastener. Kenworth uses them in pretty much everything. Like everyone said, once together they hold tight
------------- Experience is a fancy name for past mistakes. "Great moments are born from great opportunity"
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start
Date Posted: 06 Apr 2019 at 7:55pm
Before
After
Next project header trailer Bobby Mo
Posted By: Dave(inMA)
Date Posted: 06 Apr 2019 at 8:06pm
I don't know anything about those machines, but I can recognize really nice work when I see it! Cool.
------------- WC, CA, D14, WD45
