Need help locating parts
Restoadict View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Topic: Need help locating parts
    Posted: 20 Nov 2013 at 11:36am
Hello everyone. Im new to the old equipment restorations. I just recieved a HD7 and im trying to find some parts to get it moving again. It runs great and the trans goes through the gears good. The old owner took the steering clutches out of it and lost some parts. Im having a hard time finding anyone with HD7 parts. I ordered the parts manual off ebay this week so I know the right terminology for each part is. Can anyone give me some insight or atleast tell me if im on a sinking ship or not. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 2:01pm
Early HD7 with the 3-71 Detroit Diesel
Believe there are couple bone yards for construction out your way in Utah -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 2:10pm
Yes the yard you talk of is just outside of Boise Idaho. He said that he only has HD5s and HD6s :( Im not into this dozer to much as far as cost. Do you think its worth putting back together if I can find parts Coke?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 2:21pm
If there is life left in the undercarriage - being track - sprockets - rollers still have life - then yes .
Can try Eau Claire WI  - Thill Track and Tractor - see if they have a lead on anything .
 Unsure of what parts interchange on the old machines of the HD7 era .
HD5 and HD6 share many of the same parts from engine back and the running gear, in fact those machines share clutch pack parts with HD11 machines.
The 71 series engine parts are the easy part as they are still made and used . HD7 kind of stood by itself. I looked at one back in the 70's but passed and bought a D6-9U Cat - worst investment I ever made - money pit, should have bought the HD7.
Edited by Coke-in-MN - 20 Nov 2013 at 2:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 2:30pm
Ok thanks Coke. Ill check in on these leeds. I have also heard of a few out in the desert around here in the old mining districts. Im planning on going exploring after huning season ends in Nevada. Dont need to get shot at lol. Im going to take some more detailed pictures so you can see what i have. It is truly a basket case right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 5:37pm
Hey Coke I just got off the phone with a guy from fresno tractor and he has two HD7g. Will the parts from them work on my dozer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 6:55pm
Nope yours was built 1940 to 1950 / HD7G was 61 to 69 then followed by 7G-B
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 10:28pm
You might want to consider a parts tractor as well. They are around, parked, many due to a bad engine or simply something the owner did not have the money to fix.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2013 at 4:51am
zimmerman tractor in versailles Missouri has Hd7 parts for salvage
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2013 at 6:41am
I have been on the hunt for a parts dozer. There is two abandoned gold mines in the hills around here that my friends have telling about. They say that there is a couple dozers up their. Only problem ther is no road up to the mines. So no real way to get them out whole. But there are a lot of ranches and farms in the area as well. Thank you guys for all of your help. I'm going to call Zimmerman when I get to work this morning too. This weekend I'm going to try and get the dozer in my shop this weekend and ill post some more pictures.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2013 at 5:00pm
Seeing post about the K jogged my memory.From the transmission back the HD7 with a 3-71 has more in common with the K than with the newer tractors. The steering clutch from a M may also have parts in common,but I am only guessing.
Ray
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2013 at 5:15pm
Thanks Ray. Have been talking to a guy from Fresno tractor and he is saying the same thing as you. He recommended I buy the parts manual and cross check the numbers with other machines
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2013 at 11:33am
Here are the ID plates off my dozer if this helps anyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2013 at 11:34am
John NWMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John NWMo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2013 at 6:57pm
     Hi, Ray is right that K crawler  transmission and clutch parts could serve as replacements so your search might be broadend by searching for a K.  If you need a Factory service manual covering HD 7  10 & 14tractors & engines I have a factory one . Good clean manual. $35 00 plus shipping.
                   John NwMo  816 724 0206
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2013 at 8:09pm
Sounds good to me John. I ordered one off ebay but the guy was a scamer and i never got it from him so... Does it have part numbers? Also how do I get it from you? Do you have a web site?
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 1:49am
Tractor parts list HD7 clutch parts and books on his site
Also i am led to believe that the first 1000 HD7 shared the same track frame and rear end as the K but not 100% on this.
Edited by everett048 - 26 Nov 2013 at 1:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote John NWMo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 7:28am
   Service manual don't have part numbers & I just sold my K parts book so no help there. Phone number listed in previous post & is best way to contact me.
                               John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 11:57am
Ok thanks again John. I have been finding a buntch of model M but very few K models. Will model M work as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 12:33pm
Hey guys I found a picture and parts numbers. Will these parts numbers cross over to another machine that may have the part i need? I need one bevel gear #038169
Post Options Post Options   Thanks (0) Thanks(0)   Quote Restoadict Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 12:35pm
Oops I ment part# 036580
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 1:58pm
If you mean n,o 22 on the parts plate according to my parts books M crawlers are the same part n,o steering clutch bands and plates are the same to just more of them.
