Z Code Gleaner E Plugs?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Z Code Gleaner E Plugs?
    Posted: 20 Jan 2019 at 8:18am
Needing new plugs for the Z code Gleaner in my D17.  What's the best out there?  Running stock D17 distributor and points.
AaronSEIA
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 10:05am
NGK B8ES
phil
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 10:25am
NGK says B5ES for a 262. The second number is the heat range. If it's too cold, move up a number or two.
Orange Glow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Glow Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 1:07pm
I don’t know the entire science behind spark plugs, and I can’t remember the number of mine. I recently put new Autolites in my WD45 with an E Gleaner in.
My cousin and I were trying to figure out which ones to put in, and from what my cousin found out, is that the heat range on them is only the projection of the ceramic length.
I’ll check next time I see mine and give you the numbers on them, but by that time you’ll likely already have replaced yours!!
Sorry I couldn’t help more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 1:15pm
True that there is more ceramic insulator on the core of a hot plug, but it's built in a way that usually doesn't extend the tip. Too cold of a plug will foul. Too hot of a plug will burn and possibly cause predetonation.
This page was generated in 0.075 seconds.
