yugga |
drobCA
Joined: 20 Jun 2017 Location: Perris, CA Points: 292 |
Topic: yuggaPosted: 07 Feb 2018 at 10:21am |
I'm guessing this carb may need a little cleanup before it gets reinstalled.
![]() anyone else got some truly ugly discoveries to show? |
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 07 Feb 2018 at 11:28am |
na...just some fresh gas and minor adjustment..
it'll purrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr ! ![]() |
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 07 Feb 2018 at 11:43am |
I'd put it in a bucket of used motor oil and just walk off and forget about it for at least a month, longer won't hurt. Then put in carb. cleaner and let it set a few days. Don't repair any damaged places with J.B. Weld as gasoline deteriorates it. That will usually get rid of corrosion. You can use a cutting torch tip cleaner to clean out the passages, but be careful.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 07 Feb 2018 at 11:47am |
Get a coleman stove, (or some kind of outside burner), get a pot of water (I usually add some lemon juice as well) and bring it to a hard boil. Disassemble the carb as best you can, and just boil the heck out of it for a few hours. That'll usually clean it up well. Had an old army guy tell me that, and it worked one the last carb I rebuilt.
Oh....make sure you use "soft" water. We have really hard water where I live, and the first time I tried this I just used hydrant water, without thinking. Cleaned the carb, but left it chalky white. Boiled again in bottled water, and that helped remove the deposits. Edited by CrestonM - 07 Feb 2018 at 11:49am |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 07 Feb 2018 at 11:52am |
Engine, we have a problem!!!
drobCA
Posted: 07 Feb 2018 at 12:17pm |
so, Creston -
you don't think taking it in to the kitchen and asking Joyce to keep it on the boil while she cooks would work? uh... neither do i. I have an old barbecue I use right outside my little shop. and Leon - this is a "backup" carb now so I'm in no hurry. right now I have the carb and the sediment bowl (in similar condition) soaking in some old gas... then I'll move on to the boiling water, then finish up with a 3 day soak in the new formula and not so strong Berryman dip and see what I've got. I have great passage poke-out wire so I'm pretty sure I can get this working with little elbow grease but lots of patience. thanks for the help. but I still would like to see some other "horror" pictures...
CrestonM
Posted: 07 Feb 2018 at 1:40pm |
drobCA....I tried boiling mine in the house. After about 15 minutes, the smell was unbearable, so I took the pot outside, rigged up a gas burner, then boiled a couple hours out there, while the windows of the house were open, trying to air it out!
Michael V (NM)
Posted: 07 Feb 2018 at 4:43pm |
I bet your folks didn't like that...lol... Or maybe this is something they don't know about....yet?? |
CrestonM
Posted: 07 Feb 2018 at 4:51pm |
Mom knew about it...she was a little hesitant, but gave me the go ahead to try, until the fumes started coming off the water. Lol
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 07 Feb 2018 at 5:21pm |
Looks like some of the Carbs that come in to me for rebuild. Looks like something was living in them. Glassbeader will clean that up lickity-split. You may have to take a dremel tool to it and smooth out the float walls and floor of the rust worm really got to it. Looks like it did..... Renew the floats.
Steve@B&B Edited by Steve in NJ - 07 Feb 2018 at 5:22pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 07 Feb 2018 at 6:23pm |
Hadda I 400 carb that was worse'n that. Found it buried in the sand, beneath the tractor, in a junkyard... Took it to rebuilder, and told him he'd earn his money on this one...
CTuckerNWIL
Posted: 07 Feb 2018 at 6:38pm |
I don't have any pics, but the MS on my OC46 had stalactites and stalagmites totally filling the cavity . The weird thing is, I had the engine popping a few times while pulling it before I took the carb off to check it out.
CrestonM
Posted: 07 Feb 2018 at 6:42pm |
Wow Charlie, that's amazing!
DakotaSteve
Posted: 07 Feb 2018 at 7:46pm |
Put it in a bucket of acid for 6 mos.....if it's not there when u get to it at that point.....may be the best thing u could ask for....lol
drobCA
Posted: 07 Feb 2018 at 7:47pm |
yeah, Steve -
no glass beader (yet) but zero prob... I love my rototools and a nice bench job that i can do while watching a movie. and Charlie - were your "growths" hard or soft? this thing was absolutely 100% full of white powdery stuff except for a couple of places on the walls where there are hard white/grey deposits.
