Youtube video
Message Reverse Sort Order
Steve M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Quote  Post ReplyReply Direct Link To This Post Topic: Youtube video
    Posted: 04 Mar 2011 at 8:23am
John Deere plows pulled the easiest. They had to have a easy pulling plow so that their tractors could pull it.
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:54am
weight, weight and more weight !!!  I know all about the T Booster but even on a mounted plow these tractors perform much better with more weight.  They had the power but with the smaller tires they could use more weight.  Dad used 2 weights in the furrow wheel and 3 in the land wheel and 3 stacked weights on the front. This was with tires full of calcium.  When he used a pull type plow he added one more weight/rear wheel.  Pulled 4-14" SC or Pull type Clay loam ground in Clay county  Indiana. 2nd gear.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 10:02am
He had or still has a 4-16 pulltype allis plow we used before it pulled it fine too. It will spin before it will pull the motor down. My grandpa had a 4-16 oliver that had the big round pipe running the length of the plow  and I believe dad said it pulled hard. I have also seen the lightduty oliver plows that are basicaly just framework with no beam.  My dads 45 that I grew up on was a diesel that dropped the sleeve it now has a 262G and we used a 4-16 semi-mount allis the whole time I was growing up. The thing about the olivers though you can still get parts for them pretty easy.
B212,716,two 314H's,WC,WD,D19,190XT
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 8:54am
Around here Oliver had the best reputation for plows. We had a 4x16 pull-type Oliver and a 3x16 John Deere and the Oliver pulled easier than the John Deere.
Wink
I am a Russian Bot
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 8:09am
LOL, I guess I had audio from several videos going simultaneously, sounded like a plow day.  The 262 sounds GOOD!
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 7:33am
NICE!~!!!!!!!!
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 6:32am
My tractor with the C=II engine is the same tractor we pull with  and have a lot of 1st. and 2nd. it has over a 100hp. The ground it is plowing is clay loam  and the far end is black gumbo.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 7:19pm
By the way it has a 262T out of a combine.
Yea it does sound sweet DON. I bet it would easily pull that in any clay. Maybe have to run in second gear though.
Is engine out of a "C II" it looks and sounds GOOD!!!!!!!!!!!!!
Thanks for posting.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 7:05pm
Edited by CTuckerNWIL - 01 Mar 2011 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:45pm
Boys listen to that WD45-D again I think that it's got a turbo under the hood. and 16.9" x28" or 18.4" x 28" tires on it too. But it looks like a real John Deere eater pulling the plow that fast. Don
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:28pm
Man. I would love to have a 45D
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:25pm
They want pull them in this Al. red clay.
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 4:13pm
Everyone around hear always  says Inter. and J D pulls the easiest.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 11:11am
We used to think so around here. Seems like they pulled a little easier.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 10:42am
Is it true those Oliver plows were the "best"??
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 10:09am
Yep,thats it thanks for putting it on,Tucker that sounds good I wonder if they were hearing it in there sleep that night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 9:50am
[TUBE]c1LzZOKBJgo[/TUBE]
 Here's Uncle Theo and his Grandson playing with a 45D.
[TUBE]FC2ZtZBddiY[/TUBE]
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 9:45am
Is this it?
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 9:31am
If you guys want to see a 45 diesel playing with a 4-16 oliver plow. It's my uncles tractor with my dad on it. Powersteering has been added since the video.there is also one of it pulling. It was put on by simpletractor if I new how to put it on here I would. By the way it has a 262T out of a combine.
