You're not going to believe this one! |
CA Ron
Topic: You're not going to believe this one!Posted: 17 Oct 2017 at 9:19pm |
I restored a '51 CA Allis 35 years ago. At that time I installed 149 cu. in. engine I understood came out of a combine. I've never had my fingers inside this engine. Always ran real good until about a year ago when it began to start hard. Once running it ran good. Had to pull the throttle down past idle to get it to start so I thought it was a carb problem. Rebuilt it with no luck. Then new points, condenser, plugs and wires. No luck. Then compression check, all cylinders at 140 pounds. Pulled the plug out of the intake and had good vacuum. Starting to run out of ideas! Pulled the magneto out and bench tested it and the spark was somewhat weak. Installed a rebuilt mag. No luck, but now I found another problem. The mag is timed right, #1 TDC and FIRE line in the hole, I could only get 10 degrees advance with the slotted adjustment. It should 30 degrees past idle. Now what? Scratched the head for a while and decided what do I have to loose. I pulled the mag and front governor cover and turned the governor gear 1 tooth advanced and guess what, runs great! 30 degrees advance with the mag parallel with the block. Tractor runs great but I'm still wondering what's going on inside this engine???
Joined: 11 Sep 2009 Location: illinois Points: 88605 |
Posted: 17 Oct 2017 at 9:31pm |
wonder if the NEW mag is 1 tooth off on the fiber gear inside the housing ?
CA Ron
Posted: 17 Oct 2017 at 11:17pm |
I checked the rebuilt mag for alignment a couple times. I was hoping it was that.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 19 Oct 2017 at 7:19am |
Get ahold of TomMN ..... he has on his web page how to do the timing,
http://www.allis01.com/fossto/44WC/ac-wc-mag-timing.html But up at Hutch this year he showed a few of us an EASY way to do it! Had to do with lining up the damper pulley lugs. I'd rather he told you how he did it, as I'd probably screw it up. But I'll try............He took everything apart, spun the mag and the engine and then just lined it all up with #1 at the top of the compression stroke and the lugs vertical and the mag horizontal and put it back together. Fired right up on the second crank. He forgot to turn off the kill switch on the first pull. ![]() If he's at Hutch again next year, and I'll bet he will be, I'll see if he wants to do it again and make a movie out of it. It was SOOOoooo simple, I can do it!! |
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
Posted: 21 Oct 2017 at 9:20pm |
Nice tractor and loader!
