Your Collection.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Your Collection.
    Posted: 29 Sep 2011 at 6:18pm
Post all the models of Allis Chalmers tractors you own. And pictures are always welcome!!
We have a 1974 7030 and a 1979 7045. I hope to have more in the future!
Edited by R.W - 29 Sep 2011 at 6:18pm
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 7:25pm
Here is my '56 WD45 out in the field behind the barn.
Its first time out after changing all fluids but the final drives(still have that on the to do list). Here is a list of all the other things I replaced in the last couple weeks.....plugs, wires, headlight lens, headlight gaskets, alternator, battery, battery cables, alternator bracket, radiator hoses, fan belt, radiator and cap, water pump, temp gauge, manifold gaskets, cleaned carb and put a rebuild kit in it, air cleaner hose, and a new hydraulic coupler.......whew long list...but it needed to be done...feels like a new tractor.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 7:38pm
I would but my wife might look here. The official answer is I don't know how many that I have. Last two weeks a nice early ONE NINETY gas and a ACC 50 indoor forklift took up residence here.
Maurice/Pa. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice/Pa. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 7:43pm
  I have a 6080, d19d,wd45 gas,wd45d, ca, and a G.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 7:46pm
I don't have pics of all of them that I can post, only one is restored, but here is a list of the tractors, and I have 27 snap coupler and mounted AC implements.
1956 WD45 Gasoline
1956 WD45 LPG/Gasoline
1956 WD45 Diesel
1955 WD45 Diesel
1953 WD45 Distillate
1953 WD45 Gasoline
1948 WD Gasoline
1949 WD LPG/Gasoline
1950 WD Distillate
1952 WD Gasoline
1953 WD Gasoline
1939 B
1955 B
1962 D19 Diesel
Athens No. 320 Disc One Way (Snap Coupler) (12 blade) restored
Athens 6 blade disc tiller
Athens 4 bottom disc plow
Athens WD 3 disc plow
Athens #4 Subsoiler w/ mole
Athens WD Subsoiler
AC WD Disc
AC WD Toolbar Spring Chisel
No. 63 16 Slat Bottom semi mounted plow
No. 64 16 Slat Bottom semi mounted plow
All Crop Grain Drill with grass seed attachment
Snap Coupler 2 row corn planter
1973 712S garden tractor, mower deck, blade, wagon
1973 712S garden tractor, mower deck, blade, rear tiller
Oxnard Rear Dirt Scoop
Oxnard Rear Blade
Oxnard Ditching Point
Oxnard Tool Bar Blade, extensions, later style box end
Oxnard Tool Bar Blade, levers, early style box ends
Oxnard Toolbar with straight chisels
No. 7 Rake Tedder (Pull Type) (Dual wheels front/back)
No. 212 Tandem Wheel Disc, w/ T bar hitch
 No. 4 Wagon Gear
Roper Post Hole Digger (Snap Coupler)
AC No. 2, 3-14 plow (on rubber)
AC drag
82S Sickle Mower
AC#519 Hydraulic Loader
AC #445 Hydraulic Loader
Edited by Michael Crowe - 30 Sep 2011 at 9:52am
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 7:54pm
     2 - D17 gas
     1 - D14
     1 - G
     1 - 180 diesel
     1 - 190 XT diesel
     1 - 7000
                                John Carlson
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 7:55pm
Okay, I'll bite. THis is only about half the collection plus implements.
And this is my 1957 WD45 and my 1977 7060.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 8:02pm
Here are about 15 of them that I had running one day this summer, and some walk behinds.
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 8:05pm
I have 1939B, 1944B, 1946B, 1939RC, 1944WC(SFW), 1942C(WF), 1944C, 1948WD,1954WD45, 1958D-14,  ??? maybe more on way.
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 8:32pm
190XT Series 3
5030
WD
G
B
D-10
310
2-B-12
BIG TEN
B-10
B-112
Misc. implements and parts
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 8:46pm
Heres my Allis-Chalmers 5040
Heres my D-17 Series 4 diesel
Followed by my baby the 190xt
I also have a CA work in progress however i have no pictures yet.
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:00pm
   wd45d with all three front ends
   ca with wide front
   d-17 gas wide front series 3
   d-17 gas wide front series 4 fac. 3 point
   185, diesel of course, open station
   wd 45 gas wide front
   560 IHC wide front diesel turbo and 18.4 38 rears ,turbo and 18,4 38 were fact opt
   730 john ----- diesel with lots of options
   912 gt mower hydro
   716 gt mower hydro with tiller, plus lots of equipment,and parts
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:10pm
1935 22X38 AC Rumely Threshing Machine
1938 B
1940 40 Allcrop
1941 WC
side mounted sickle mower
side delivery rake and tedder
2 bottom & 3 bottom Pin hitch plows
Flight Line Elevator
Super 100 Allcrop
1957 D14
snap coupler rotary hoe
160 3- point rotary mower
B 10
B 12
9000 pull type 5 or 7 bottom plow
1966 Gleaner E
HB 112
HB 212
701 Wagon gear
416 Shuttle
Sprint 830
716 6speed
716 Hydro repowerd
1979 7020 power shift one owner
1979 N6
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:20pm
two C's
B with C front end
!958 D17
D17 series 4
185
And hoping to add more this next year.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:27pm
Our Family collection above and our 170/175 line up
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:28pm
1954, WD45G NF
1955, WD45G NF charlynn PS Freeman trip bucket loader
1956, WD45G NF factory PS
1957, D17G was NF now WF
1959, D17G WF
1963, D19G WF factory 3pt
1972, 200D Year-around cab w/ Great Bend 880 loader
1976, 7040D CHA
1976, 7060D CHA
1979, 7080D had CHA now open station
3-14 snap-coupler plow
4-14 9000 series semi mount plow
5-16 9000 series semi mount plow
21ft 2300 disk manual fold
24ft 1300 DA field cultivator
26ft 2500 DA disk
If you add Grandpa and uncles the list is a mile long.
Edited by Dans 7080 - 29 Sep 2011 at 9:34pm
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:29pm
That is a lot of tractors, WOW
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:30pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:46pm
Here are mine that are currently running - 2 D14s, D14 IV, 6080, 620.
190 XT that just had the transmission and rear end rebuilt
The ones currently incapacitated (for good reason)
175 - awaiting restoration
D15II - in process of being restored.  Hope to have some paint on it in the next 2 weeks.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 9:57pm
My '39 B, '40 B, and Dad's '52 WD:
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 10:02pm
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 10:03pm
wow i messrd that up  i have no idea what im doin sorry  we have a 17 a 180 ,XT and a 7045
190XT,D17and 7045
DeanSWMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DeanSWMO Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 10:34pm
20-35
A (2)
U
UI
UC
UC Thomson HC with GM Diesel Cane Loader
WC (to many to count)
36 WC HC
39 WC HC (2)
WC Thomsom HC Cane Loader
IB (2)
G (3)
B (2)
WD45D
WD
WD45 (2)
D10
D12 Industrial
D12 HC
D14
D14 Industrial Shuttle end loader
D14 with backhoe
D15
D15D
D17
D17D Thomson
D19
D21 (2)
W Speed Patrol (2)
160
180
200
5015
8030
SP100
110 manure spreader
mounted 33 corn pickers (3)
Lots of SC equipment
Lawn Mowers
B1 (3)
B10
Big 10 (3)
B12 (2)
And a about 20 different number mowers
Everything above runs. Catch us at a show have a notebook with pictures of each one.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 10:52pm
Not counting parts tractors, here are ours:
1970 B208
1950 C Wide Front
1948 C Single front wheel
1948 B w/ adjustable wide front
1939 WC "Hi-Crop" Vegetable Special
1938 "Styled" WC
1937 WC
1939 RC
Edited by Kip-Utah - 29 Sep 2011 at 10:54pm
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 11:03pm
50 WD with 55 WD45 4 bolt wfe also have narrow front, dads 55 WD45 with WD9 Loader, 48 Rotobailer, #3 and #7 sickle bar mowers, Forage blower and a Allis Chalmers roto tiller.  Also have a David Bradley rake and manure spreader.
Forgot to add 2 bottom and 3 bottom s/c plows and a 2 bottom rollover that needs some parts to work.
Leonard
Edited by Leonard - 29 Sep 2011 at 11:15pm
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 11:41pm
My Tractors:
1941 C #2123
1952 IB #2256
Dad's Tractors:
185
200
7045
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2011 at 12:13am
Tractors: 1936 WC, 1946 WC, 1950 WD, 1954 WD45, 1958 D17 series I, 1959 D17 series I (bar grill), 1960 D17 series II, 1964 D17 IV, 1962 D19 diesel, 1975 200, 1975 7060, 1984 8050, 1985 8070, 1983 Simplicity 7119 hydro, 1951 Massey Harris 44.
Equipment: AC 3pt 6' blade, AC 72 combine, AC 90 combine, AC 170 picker, John Deere #38 sickle bar mower, AC 80R parts mower, Letz feed grinder, AC 8' snap coupler disc, AC 2-14 WD pick up plow, AC 2-14 #2 hyd. lift pull plow on steel, AC 3-14 model 53 sc plow, AC 4-14 model 74 sc plow, AC 3-16 model 2000 semi mount plow, AC 4-16 model ? semi mount plow, IHC 3-16 model 60 hyd lift pull plow, IHC 3-14 #8 mech lift on steel, IHC 2-14 #8 mech lift on steel, IHC 2-14 #8 mech lift on rubber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2011 at 12:22am
Originally posted by XT in pa XT in pa wrote:
our 1<a href="http://s82.photobucket.com/albums/j268/shawn190xt/?action=view&amp;current=HPIM0521.jpg" target="_blank"><img src="http://i82.photobucket.com/albums/j268/shawn190xt/HPIM0521.jpg" border="0" alt=<a href="http://s82.photobucket.com/albums/j268/shawn190xt/?action=view&amp;current=HPIM0357.jpg" target="_blank"><img src="http://i82.photobucket.com/albums/j268/shawn190xt/HPIM0357.jpg" border="0" alt="Photobucket"></a>"Photobucket"></a>80, my XT
Oh man those D21's are looking great, both yours?
