You win some.....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: You win some.....
    Posted: 15 Mar 2013 at 10:06pm
you lose some. Hooked the disc up to the new  185D for its maiden voyage today. Great smooth power, but it had a clinking noise in the tranny I was concerned about when I got it home. Well, two hours of discing and I guess the oil thinned out and now it sounds like the tranny could grenade at any time....sure wish the Ebay ad had stated it had noise in the rearend....
ALLIS EXPRESS!
This year:
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 12:33am
Yes but Eldon, if they would have told you it had a noise in the rearend you wouldn't have bought it and the previous owner would still own it!  Sorry for your problem, hope it isn't too bad to fix.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 5:45am
Yep, been there done that.  I feel for you Eldon.  You know that old phrase well, "Buyer Beware".  Still true today, even more so.  Hope it works out for you though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 8:12am
I guess....just expected a little more from a forum member....
ALLIS EXPRESS!
This year:
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 8:13am
Maybe it finally worked all of the saw dust out of the bearings.
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 9:07am
Happens a lot. Last summer I bought a WD. The seller failed to tell me the steering gears were worn out. He had the tires about half full of air and the gear housing full of thick grease. When I got the tractor home I aired the tires up. After going through the gears, hydraulic and other functions I took it out on the road, put it in 4th and opened it up. It started to wobble and shake so bad I almost lost it. Took it back to the barn, pulled the gear cover and discovered the grease tightly packed in an attempt to cover up the worn out gears. After replacing the gears twice before I found a good set it now works as it is supposed to. I'm sure the seller knew about this but failed to tell me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 9:55am
Whoa,, a forum member here !!!! Holy crap
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 12:07pm
I would love a 185D, and I like to buy them cheap with problems, how much do you want for her?  Free Shipping to right?  :-)
Still in use:
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 6:32pm
I've had similar problems.  Got a one-eighty with transmissions problems.  Lucky I discovered it had issues before paying for it, but didn't discount it enough for what it is eventually going to cost me to fix it right.  Oh, well, at least I finally got the one-eighty I had been looking for.  Dave
This page was generated in 0.152 seconds.
