york compressor for air |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Topic: york compressor for airPosted: 30 Jul 2025 at 4:32pm |
any one use a york a/c compressor for compressed air on their tractor
Joined: 11 Sep 2009 Location: illinois Points: 90838 |
Posted: 30 Jul 2025 at 4:51pm |
i mounted one on a 10 gallon tank with a 1/2 HP motor.. about 30 years ago... to use out at the farm house.
Michael V (NM)
Posted: 30 Jul 2025 at 6:43pm |
I had one rigged on my farm Pickup with a tank off a semi truck,, I put a pressure switch on it with a master switch in the cab. worked ok,, just not a lot of volume to run air impact and such, seemed like I was always waiting for it to rebuild pressure...
one thing,, check the oil every so often,, I messed up a couple by letting the oil get low.... Edited by Michael V (NM) - 30 Jul 2025 at 6:46pm |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 31 Jul 2025 at 11:15pm |
You CAN... but a better choice would be to fit an electric clutch to a conventional 2 cylinder air compressor head. The York is a real bulldog of a refrigerant compressor, but it is designed to pump a lower volume, higher pressure, and the refrigerant is also the cooling medium for the compressor. An air compressor cannot do the same (hence, the exterior cooling fins) and has a significantly higher volume in working range.
HudCo
Posted: 01 Aug 2025 at 9:25am |
you can buy these yorks now already set up for air compressor with a finned head and differant piston and rings , i guess the four wheel drive guys like them
