york compressor for air
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: york compressor for air
    Posted: 30 Jul 2025 at 4:32pm
any one use a york a/c compressor  for compressed air on their tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 4:51pm
i mounted one on a 10 gallon tank with a 1/2 HP motor.. about 30 years ago... to use out at the farm house.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 6:43pm
I had one rigged on my farm Pickup with a tank off a semi truck,, I put a pressure switch on it with a master switch in the cab. worked ok,, just not a lot of volume to run air impact and such, seemed like I was always waiting for it to rebuild pressure...
one thing,, check the oil every so often,, I messed up a couple by letting the oil get low....
Edited by Michael V (NM) - 30 Jul 2025 at 6:46pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 39 minutes ago at 11:15pm
You CAN... but a better choice would be to fit an electric clutch to a conventional 2 cylinder air compressor head.
The York is a real bulldog of a refrigerant compressor, but it is designed to pump a lower volume, higher pressure, and the refrigerant is also the cooling medium for the compressor.  An air compressor cannot do the same (hence, the exterior cooling fins) and has a significantly higher volume in working range.
