Yet another question on my D14... |
Allis-Chalmers Damon
Joined: 13 Apr 2015 Location: Deer Park, WA Points: 108 |
Topic: Yet another question on my D14...Posted: 29 Apr 2019 at 11:37am |
Hello all,
My D14 was due for new plugs and wires and just an overall tuneup. I bought a tune up kit that included Autolite plugs, plug wires, cap and rotor. I installed everything and noticed that the new cap jiggles slightly on factory distributor. I have never really paid any attention to the movement of the cap so I am not sure if this is normal? The old cap and new cap were identical looking and it clamped down tight, but I am noticing it moves around on the distributor slightly... Tractor starts right up and runs really good so I believe everything is timed correctly. Sorry for my lack of knowledge! Thanks
1955 WD45 Diesel, 1959 D14, All-Crop Drill, 2015 John Deere 5075e, New Holland 279 Haybine, New Holland 575 square baler, New Holland 1032 Stackliner, 10ft Industrias Disc, 6ft Titan grapple
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 29 Apr 2019 at 11:56am |
Damon, that is truly strange. I'll check mine to see if it does the same thing.
WC, CA, D14, WD45
Posted: 29 Apr 2019 at 12:10pm |
Thanks Dave. The movement is very little but still something I noticed. I did a bit more research and it could possibly be due to the new plug wires not being hard wires, they are the flexible kind which would allow for more movement on the cap. The cap is clamped down tight and fits great. I also noticed my old cap had a light flim of dirt inside which leads me to believe there is a gap between the distributor and cap...
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 29 Apr 2019 at 12:21pm |
Rotor hitting cap
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 29 Apr 2019 at 1:21pm |
The last rotor and cap I replaced the rotor didn't want to seat all the way. I scraped the inside and tapped it down where it belonged. That was last spring. |
Dave(inMA)
Posted: 29 Apr 2019 at 2:54pm |
If the cap is locked down tight and is moving, something has to be pushing it - "Rotor hitting cap" sure makes sense.
WC, CA, D14, WD45
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55299 |
Posted: 29 Apr 2019 at 5:38pm |
IIRR, the cap has a slot stickin out that engages the female slot, in the bakelite points and condenser cover, and that has about a 3/8" slot, to be indexed properly. Check for chip outs, and proper seating, too!
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 29 Apr 2019 at 9:10pm |
Do you mean "it is moving"? Like moving when the engine is running?
Or you can "move it" like wiggle the cap by hand? Only reason I ask is my brothers D-14 is the same way. You can move the cap by hand, starts and runs beautifully.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
