Year of my CA? |
Post Reply |
Mikemcrn
Bronze Level Joined: 07 Sep 2010 Location: New Jersey Points: 7 |
Posted: 07 Sep 2010 at 7:48pm |
Is there any other way to tell exact year of what I believe is about a 52 CA without the serial number by the shifter (Missing), I just bought this last week and may have alot of questions to get her started. Will push starting help to see how much work I may have in electrical alone? Any help greatly appreciated. |
MNLonnie
Orange Level Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
You can check the engine serial # or look for casting dates on motor or elsewhere. Casting # on motor should be AM####-##, the last to should be 24 if it's a 1952.
DREAM
Orange Level Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Welcome to the forum! I would assume the tractor had the tranny casing replaced at some point. I think the engine ser# should be on the rear engine flange, left side if sitting on tractor. Not sure if CA still had CE series engines or not, but ser should start with 2 letters then numbers. Letters may be CE. Somebody else will be better on CAs than me. Push starting will work, just make sure you have someone else to push. Be careful. Hope this helps.
Chalmersbob
Orange Level Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
The CA still had the CE engine. The early ones had a Mag and later ones had battery ignition. If you have a Mag, then you can pull or push it to get it running. Nice tractor, I have 3 of them. very powerful for there size. Bob
Mikemcrn
i am sure i have seen this on the casting, thanks so much. will check again
Mikemcrn
would the magneto be just behind the radiator on the right side in front of coil and (points/condenser)?
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6241 |
If it has an external coil you will need a battery to provide voltage for the coil to produce a spark. In a magneto ignition the coil is built into the magneto and the magneto generates its own voltage. BTW - Welcome to the forum.
Mikemcrn
AM 3796-1 WITH AN X UNDERNEATH THE A ON LEFT OF ENGINE CASING BELOW CARB???? Also with 3797-6 on left rear axle and 3798-8 on right rear axle, both axles seem to have an H enclosed in circle above these numbers |
Mikemcrn
Mikemcrn
sorry for same posts, was trying to respond to individual post. If I have a battery does that mean no magneto?....Thanks for your replies. I will not bother you all too much and plan to have some motor heads help me till I get closer to real operation and implementation
Hubert (Ga)engine7
Many of the magneto ignition tractors had a battery. The battery powered the starter and the lights but was not necessary for the engine to run. There should be only a grounding (kill) wire running to the magneto if it has a wire at all. Some only have a grounding tab on the side of the magneto.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22818 |
Here is a list of tractor numbers and corresponding engine numbers. http://people.clemson.edu/~wsmth/SNFind/esn_tsn3.htm
Here is the info about the casting number on the right front of the block. http://people.clemson.edu/~wsmth/engcast.htm I have a 1951, CA669 with an engine serial number that matches up to the first chart as an early 1951 tractor but the casting number, according to the second chart is a 1956. Dad bought the tractor new in 1951 and it still has the original engine in it so the casting number thing doesn't always work out. Pushing or pulling won't tell you much about electrical. If you have a distributor you will need a battery to get it to run. If it doesn't have a battery now and you need it for spark to the distributor it might be best to disconnect the generator from the system. You don't know if it is positive or negative ground and you might let the smoke out of the genny if it still has some in it. If it has a magneto you don't need any electrical system except to run lights. |
Mikemcrn
Thanks All, Scraped off all the old paint and rust and got both numbers. Turns out to be a 1955 CA. Thanks Again. Mike
Post Reply | |
