XT 190
dog catcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dog catcher Quote  Post ReplyReply Direct Link To This Post Topic: XT 190
    Posted: 23 Mar 2021 at 7:55pm
THROTTLE ON 190 WILL LET TRACTOR IDLE BUT WHEN FULL THROTTLE TRACTOR WAY OVER REVS HELP PLEASE
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 8:07pm
Gas or diesel ???  How do you KNOW it's over revving??
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 6:58pm
I had something like this occur when my injection pump started to fail.  The throttle lever would not control the engine RPMs and it would race on it's own, but I don't think the rpms went past 2300.  What does your tachometer say when this happens?  My tractor would also die off and on as the pump failed, so the failing pump created all kinds of issues.  I had leaking fuel out of the timing inspection plate too.  Anything else like that happening?  I see you are fairly new so suggest you document as much as you can about the problem for the best help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dog catcher Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 3:30pm
just by sound of engine it is gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 3:38pm
Gas engine has spark plugs, diesel has injectors. So which is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dog catcher Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 3:59pm
it is a gas engine
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 8:48pm
I would say misadjusted or worn linkage between governor arm and carburetor .            MACK
This page was generated in 1.469 seconds.
