XT 190 pyo brake |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: XT 190 pyo brakePosted: 15 Apr 2017 at 6:40pm |
Have a persistant hydraulic leak at a tee fitting down by a drain plug for i think is tranny. The T has male thread going into a round housing held in with s snap ring, a short hose from another round housing rainbows up over a center round housing into 1 side of female part of T, the other female side has a steel line going back to valve stack, as well as a steel line from middle round housing I am 95% sure this related to pto brake valve if I read part diagram correctly. I am needing the T - #70914762 in Agco parts book but hoping someone can verify my part. Tried getting the T at our local hydraulic repair shop but no dice. Tractor does have hydraulic pto engagement. Thanks.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 15 Apr 2017 at 8:12pm |
That is the correct part number for that tee.
FREEDGUY
Posted: 15 Apr 2017 at 8:15pm |
THANKS. There are GOBS of pages for hydro system,not to mention the serial # breaks.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 15 Apr 2017 at 8:28pm |
I was surprised the AGCO parts book has a hose between the Brake pistons. My 190XT has a steel tube, The tee has an 1/4 npt thread on the side and 3/8 inverted flare connections on the run. I looked at another housing I had, but the tee was broken off and the tube/hose was missing.
I would double check to see what was actually used on your tractor. |
FREEDGUY
Posted: 15 Apr 2017 at 8:44pm |
Joe, the hose is what is on our tractor, I just removed the TEE this afternoon and discovered the male stem was almost broke in 2 and I accidently finished it off. You guys seem to be "IN THE KNOW" about parts,could either of you tell me if this part is still available anywhere in the USA ?
Albert
Posted: 15 Apr 2017 at 8:59pm |
I have a new old stock here I will send you a PM
Albert |
Lynn Marshall
Posted: 15 Apr 2017 at 9:08pm |
An Agco dealer should be able to give you price and availability. Plus they should be able to check other dealers inventory to see if anyone has it in stock. (Not likely). And welcome to the forum.
FREEDGUY
Posted: 15 Apr 2017 at 9:13pm |
Lynn, thanks for the welcome but i have been a member for several years but some how had a snafu last week when editing my profile. Had to do like Shameless.
