XT 190 Flywheel Ring Gear
bharper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Topic: XT 190 Flywheel Ring Gear
    Posted: 25 Jan 2018 at 9:55pm
We have been working on our XT 190 Propane the last couple of days and we noticed the starter was not engaging all the time. I took the starter off today (in a position that it wasn't engaging) and the teeth on it are worn down pretty bad and the flywheel ring gear teeth are worn some, but not too bad. Would you split it and replace the flywheel gear? Split it and rotate the gear some? Or leave the flywheel gear alone?
Thanks
Allis Magoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 10:02pm
If you rotate it its eventually gonna fall back into that bad spot. I would start with the starter
Edited by Allis Magoo - 25 Jan 2018 at 10:03pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 9:48am
if your going to split it, don't wast your time rotating the ring gear just install a new one and youll be good for another 40+ years
concretepumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concretepumper Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 6:09pm
Anytime we have had to put a clutch in we always flip the ring gear
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 4:03pm
Will the ring gear off a M2 301 flywheel work on a 301 flywheel on a 190XT
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 7:05pm
Yes.
