WTB WC/WF Part
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Topic: WTB WC/WF Part
    Posted: 28 Apr 2021 at 9:52am
I need the rod and thumb lever for the gearshift reverse lockout.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 8:07pm
do you have part numbers
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 11:30pm
70202761 is the little lever I think. AGCO parts calls it a spoon.
The rod shows a serial number break. WC serial prior to #76982 or WF serial prior to #1904 is 70202785.
The rod for WC #76982 and up or WF #1904 and up is 70208825. This one had a couple ** with a note saying WC**: W/Shift Rod Supports integral w/Control Cover (Used in year 1935 & UP) but I think that is a typo and refers to the shifting rods inside the shift cover because I know from 1935 on the cover changed and the rods were retained differently.
That's if I looked it all up correctly..... but I'm sure I'm right though.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 6:32pm
have card on the 202761
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 7:00pm
Lonn, Thanks for locating the part numbers and Mikez, I have a lever that can be used with some work.   The rod is the part that I need the most.  I am sure I can fabricate one, but hoped to find an original one.
This page was generated in 0.664 seconds.
