WTB: Spring tooth harrow parts |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Topic: WTB: Spring tooth harrow partsPosted: 11 May 2016 at 8:55pm |
I have a spring tooth harrow that is missing two front shanks. There are four shanks in the back row and three in the front. I need two of the front ones. I need the brackets with the two set screws that mount them as well.
http://simpletractors.com/attachments/harrow.htm Thanks in advance. Edited by littlemarv - 14 May 2016 at 2:54pm |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
littlemarv
Posted: 11 May 2016 at 9:01pm |
If someone would be kind enough to post how to make that a live link, I promise I will print it out and tape it to my end table next to my chair so I can do it myself!
Herb(GA)
Joined: 15 Sep 2009 Location: United States Points: 1039 |
Posted: 13 May 2016 at 8:10am |
Tri-State Show, Portland, IN, May Swap-meet and August Show is a good place to find such items. Actually, most any large show. Le Sueur, MN is probably much closer for you. And you may find at some small show with only a few old iron venders. Suggest taking along a sample to insure you get the identical item. Happy hunting. Herb(GA)
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 14 May 2016 at 12:34am |
can you post a pic of what you need? I have a few old harrows here I can dismantle!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 14 May 2016 at 4:47am |
link comes up as NG...http:// www.simpletractors.com/attachments/harrow.htm
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 14 May 2016 at 6:09am |
Take the www. out of the link Gary http://simpletractors.com/attachments/harrow.htm |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 14 May 2016 at 1:54pm |
littlemarv
Posted: 14 May 2016 at 10:29pm |
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 14 May 2016 at 11:35pm |
You only need one as it only supposed to have six springs on it. That will be a very hard part to find as these harrows are very rare.
AC part numbers needed = 72026899 Standard 72026901 Spring 72025769 Clamp 72025756 Nut -special (available at The Parts Depot in WI) 72026900 Bolt -special (qty 2 req.) Here is a link to the parts manual with Simplicity part numbers. http://bsintek.basco.com/BriggsDocumentDisplay/heCBEN8aqNZrE3Cvh5kbp796Dq.pdf I think your best shot would be finding another incomplete one and making two, or maybe some of these parts are laying on an old dealer's shelf somewhere. |
littlemarv
Posted: 15 May 2016 at 12:06am |
All the ones I have ever seen have 7 shanks. Like in the link above.
I was hoping to find someone that has a partial one laying around... |
Dnoym N. S. Can.
Posted: 15 May 2016 at 6:00am |
ACmowerguy
Posted: 15 May 2016 at 5:23pm |
Parts book is wrong, my bad.
![]() ![]() Should have known better as I have one of these harrows out back. |
littlemarv
Posted: 15 May 2016 at 10:32pm |
So the spring teeth are all the same, its brackets #13 and #16 that make the difference.
Any any rate, I still need two whole assemblies for the front row of tines.... Are these really that rare? I sure like the way it works the ground up, I'd just like to get it back to original.... |
SHAMELESS
Posted: 19 May 2016 at 10:19pm |
i'll look see what mine look like
Matt Tallant
Posted: 04 Sep 2016 at 7:45pm |
I have the parts you need if you Havnt found them.
Mikez
Posted: 04 Sep 2016 at 10:42pm |
I would like to find a harrow like that
