WTB Shares for Pickup Plow
jlaage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Topic: WTB Shares for Pickup Plow
    Posted: 28 May 2025 at 7:56pm
I'm looking for replacement shares or lathes for a pickup plow that was paired with a 1950 Wd
jiminnd View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 9:19pm
14 or 16 inch?  this is the old black smith sharpened ones?  I have a set but would have to check the size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 6:42am
Without a number from the share you have unless you are absolutely sure what bottom you have asking for share is like throwing darts in the dark. There are 27 different bottoms that AC used and most shares don't interchange.  I have a few NOS shares available for the #24 & #124 bottoms, also a single LH share for a #325 14" bottom.
  If you can't find a number on the underside of your share, look for a number on the back side of any wear part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 10:30am
This is a picture of the share I need to replace.  Does anyone think it could be welded?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 10:39am
The number on the part is 37-16SC    A number 45 also appears nearby.  Not sure my picture got throughuploads/25655/IMG_1493.jpg
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 7:06pm
  That number is NOT an Allis Chalmers number but someones aftermarket number. However I'd say you have a #37 bottom that has a 16" cut. Is it a slat bottom?
  With all the the plow parts book shows 2 shares for the #37 bottom:
  321558  &  321559
Post Options Post Options   Thanks (1) Thanks(1)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:21pm
I have about 10 old plows, they all have one bolt and the hook for the j draw bolt.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:18am
Here's some tips on how to repair shares. https://youtu.be/b1iuiqzQ4BQ?si=qSYtFrHxr_bIjhAK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:34am
This is a slat plow with one bolt and one hook  There are only two holes in the share.
I'm having trouble getting more pictures posted  will keep trying
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:41am
Sounds like you might have one that woud work for me if you'd care to sell.  looks like 16 inch bottoms and two holes with one for the draw hook.  I have the old bolts but theyre rough so if any of those are available that would help
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 23 minutes ago at 4:00pm
  321558  &  321559
   I have the book issued with this plow, it provides drawings but no numbers.  There is a drawing of the #37 bottom.  I appreciate your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlaage Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 19 minutes ago at 4:04pm
This page was generated in 0.754 seconds.
