WTB fuel line
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: WTB fuel line
    Posted: 13 Jun 2021 at 12:53pm
Looking for a good used, or new, fuel line for a 170 gas, black stripe.  Thank you!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2021 at 8:23pm
Buy some steel brake line and some tube benders and make your own.  Pretty easy.  I have made a few.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 12:28pm
Thanks DSeries 4, I got some tubing at napa but it kinked too easy in the bender.  Might use what didn't kink and splice in a rubber hose and in line filter temporarily as the tank was really rusty/gunky.  Got it cleaned out, but don't want to mess up an expensive carb rebuild.  Probably end up repairing the original line to use in the future if I can't find a replacement
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 11:18am
How sharp a bend do you need. Usually can do at least a 90 with no problem. Brake line is cheap. Buy a roll and start practicing. 20ft coil is maybe $25.  If the steel is too hard for you use copper nickel line. It is real easy to bend. It does turn green after awhile so clean it occasionally or paint it.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 7:55pm
Thanks Ed, I'll try that, 90 degrees is the most bend I need
