WTB "flower pot" dual adapters
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: WTB "flower pot" dual adapters
    Posted: 15 Apr 2011 at 6:52am
for my 7050. What kind of money should I expect to pay for a set? Should I just try and find a good used extended axle to replace my damaged one so I can use my regular axle mount hubs? Anybody have a good extended axle for a 7050. It is 3 5/8" diameter. Thanks
Wink
I am a Russian Bot
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 7:43am
Lonn,
I have a set of the flower pot (9 bolt) hubs for sale.  $100, located in SC MN.
Chad
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 5:57pm
 I thought I saw a 6080 on Tractor House with those "flower Pot dual adaptors.  I had never seen a 6080 or 185 tractor set-up that way. I looked pretty cool. Are the bolt patterns in the cast the same for all AC tractors?
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 7:42pm
Ranger, I do think all the 34" and 38" cast centers have the six-hole pattern for mounting wheel weights or dual hubs.  A 185 would have to have non-factory wheels to use the dual hubs.
The innovators offer what others will imitate.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 8:48pm
When I ordered new studs for my "flower pot " dual adaptors last year, I found out there are two sizes of studs so I'm assuming that there may be a light version (possibly for D-19/one-ninety) and a heavier version with heavier studs for D-21's etc. I didn't take time to surf through the parts book and maybe someone else has more info.
