Wtb d17 2 way hydraulic valve control
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 10:26pm
After doing a few of these over the years, I have never once used a pump larger than 10 GPM. This is based off of the wildly popular series 4 D-17 which was actually 12 GPM at full throttle and more GPM than a 50 HP tractor usually needed. Special projects may be different, but if a series 4 was ALWAYS plenty, most users will be happy doing nearly the same thing. I have also never seen the need for a separate oil tank. The existing sump can easily be tapped into to get oil from the tractor and return the same oil thru a filter. The sump capacity is more than adequate, especially when using 2-way cylinders. There is no oil overheating. There are no problems. There are no tanks to build to take up extra space.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 9:21pm
Originally posted by Hunt4Allis Hunt4Allis wrote:
Hmmm, I'd love to see that setup so I can get an idea of how to do it right...
We have front pump mounting kits for D14/15/17 available for purchase. You can use your own pump with SAE 'A' mounting or we have 9.5GPM or 14GPM bolt on pumps available too!
www.awtractor.com
A&W TRACTOR 920-598-1287
This page was generated in 0.563 seconds.
