WTB D15 distributer
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Topic: WTB D15 distributer
    Posted: 26 Feb 2022 at 10:14pm
I assume they are the same on all the gas D Series, mine is so rusted it probably is more work to fix then a good one is to buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 12:09am
I believe there all the same. I have one off a D17 that i will sell. Send me a PM if your still looking. Thanks
Owner of Matt Scott LLC
http://www.mattscottllc.com/
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 4:24am
Have some also. Ryan at 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:43am
D14 before serial #D14 19001 used a Delco 1111745
 later D14 used 1112593
 D15 tractors (series I & II) used 1112607
 D17 tractors with an engine serial number below 17-19978 used a 1112584 and the later ones used a 1112693
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:34am
They are NOT all the same as Paul posted above. What's the number on your Distributor?
I have rebuild Distributors on our website if interested.
Steve@B&B
bb-customcircuits.com
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:11pm
They are pretty easy to take apart and there is not much to them.  Rusty parts are easy to clean up with a wire wheel or glass beads.  This stuff just costs your time.  Less than buying another one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:17pm
what is different on the distributors that would make it impossible to install ONE model on a different tractor.......... say a D15 distrib onto a D14 ?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 7:10am
Steve ,it's in the advance
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 3:15pm
As Fred mentioned, the advance is different. They all will drop in (and probably work) but the centrifugal advance is different from engine to engine. Hence the different part numbers on the Delco tag. When a customer needs a Distributor for his or her Tractor, I always ask them what the number is on the tag. I then give them the same Distributor as an exchange.
Steve@B&B
This page was generated in 0.219 seconds.
