WTB AC 7040 Fuel Line
Midwestquest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Midwestquest Quote  Post ReplyReply Direct Link To This Post Topic: WTB AC 7040 Fuel Line
    Posted: 02 Jan 2021 at 10:18pm
Howdy,
   Looking to buy fuel lines for the maroon belly AC 7040 tractor. Line #2 was welded onto the nut, tried everything i could think of and it still works, but its kinked pretty bad. Ill but a set or just 1.
Steve
7040
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 9:00pm
AGCO used to still have them available. It's been a few years now, maybe 2011 or 12 but I needed one for my 7050 when it cracked while I was plowing. It was just over $100 then.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Midwestquest Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 12:33pm
I looked on AGCO parts with the part number, should I be using a different number?
7040
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 3:24pm
74029662 is the number but just call your closest dealer and tell them that you need the #2 line going from the injector pump to the #2 injector. Unless someone has a used line for you.
Wink
I am a Russian Bot
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 7:39am
do you have allis (line goes in side) or bosch (line goes on top)I should have both kinds
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 9:29pm
if you get new one be sure to order the new nuts and sleeves also. Let me know if I can help you out.
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Midwestquest Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 11:13am
I couldnt find them new but the used parts market was good to me, thanks guys.
7040
This page was generated in 0.230 seconds.
