WTB: 7010 Weight Bracket and Clamp on hubs
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: WTB: 7010 Weight Bracket and Clamp on hubs
    Posted: 27 Jan 2021 at 1:19pm
Need a front weight bracket for 7010 and a set of clamp on dual hubs 9 bolt.  Let me know if you have any for sale.  I understand shipping could be expensive if not here in the midwest.  My zip code is 46044 if someone wants to estimate shipping to give me a total price.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 9:37pm
I have 3 5/8 9 bolts hubs , may have weight bracket also thanks Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 10:23am
I will PM you.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 8:35am
I have purchased a weight bracket so still in need of hubs.
Dave974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave974 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 11:19am
I ran across this post on Facebook marketplace:   https://www.facebook.com/marketplace/item/404230034174315
Not mine but wanted to pass it long in case those would fit the bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 1:44pm
Thank you!  They aren't far away either.  I sent a message.
I wonder if these are made by Allis or just fit on Allis?  They are 9 bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave974 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 2:05pm
Sure, glad to help!
Not sure but I'll bet those are universal.  They look very similar to 9 bold hubs I've seen on other brands, just with different paint colors.  My 7010 has T-rail duals, so nothing to compare it to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 2:57pm
Do you have weights on the front of your 7010?  If so, is there a different weight bracket for the 75 lb weights versus the 100 lb weights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave974 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 3:57pm
Yes.... and the same bracket works fine for both weights.  The shape of the weight is exactly the same.  The only difference between the 75 and 90 pounders is the thickness of the weight slab itself.
In fact, I have the thin (75lb) weights on my 7080 and and thick (90lb) weights on my 7010 and I sometimes mix and match between the two, no issues.
There were two different widths of brackets available.  Most tractors have he standard bracket which holds 15 thin or 10 thick weights.  If my memory serves me correctly, the optional extra-wide brackets hold 21 thin or 14 thick weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 12:38pm
The hubs the guy on marketplace had were for a 7000 which is 3 1/4 axle size so didn't work for me, but I did get 10 front weights with keepers at a good price so it was still a good trip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 5:45pm
Having trouble finding hubs for 3 5/8 axle. Guy has t-rail duals which I think are less desirable but tires are 50%. Thinking $400 for pair. We will see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 10:26am
I do have three sets but under snow right know 5o7 766 o551
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 10:48am
Steve, I sent you a PM a few days ago but thanks for the phone number.  I will call later.
This page was generated in 0.184 seconds.
