WTB 226 high compression pistons
ACmutt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Topic: WTB 226 high compression pistons
    Posted: 14 Dec 2022 at 9:55pm
Looking for 4 1/8 high compression pistons for a 226. Wonder if anybody makes them? Would like to get compression around 250.
Edited by ACmutt - 14 Dec 2022 at 10:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2022 at 10:18am
Used to be if you found a set of M & W's from a WC/WD (SP46 kit) they were the ticket. So, if by chance you can get a modern day set of 4 1/8" for a WC/WD and use them with the WD-45 crankshaft, you should have something higher than average. Compression height (piston pin center to piston top) is the key.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 9:45am
I have a set of 4&1/8" flat tops. Comparing them to an M&W, the head of the piston is a little lower but they don't have that massive bowl. I can send pics if you like. I believe they are JCC brand? That is the only marking on them.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 11:46am
These are SK156 Flat top pistons compared to standard D17 spec pistons with wristpin lined up.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 11:47am
I have to run 93 octane with those
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:17pm
Did you ever run a cranking compression test ?? like maybe 200 psi ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 8:23am
Thanks, if you could send me a pic that would be good. Do you want to sell them, if so what is the price.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 1:10pm
should have some used  ap46 m&w
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 1:54pm
Steve I would be interested in those. PM me with price? Will you ship?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 3:02pm
WARNING: SP-46 M & W brand pistons will require removing .150" off the piston tops to avoid hitting the cylinder head !! You measure them to verify this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 5:28pm
Thanks for the input Dr, I appreciate your help.
