Wrong tractor - Cub
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: Wrong tractor - Cub
    Posted: 21 May 2020 at 10:23pm
I have a Cub - the light switch on the later Cub's have a spring like wire between two of the contacts. What does that do?
Larry Miller
I used to be young and stupid, now I am not young anymore.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 10:28pm
Sounds like it's a resistor.  I'm not sure of the reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:12am
high - low charge , similar to 'B' light switch ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 6:46am
Could also be the resistor for "Dim" headlights.  All Farmalls have Hi/Low headlights.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 7:07am
As Jay mentioned, Hi or Lo charge; also mentioned the HI was for Field work and Lo was for Road use, less blinding the oncoming traffic.
6 volt or 12 volt?
Edited by JoeO(CMO) - 22 May 2020 at 8:49am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 10:46pm
When lights are on, generator field goes to high charge to compensate for lights-on draw.
This page was generated in 0.087 seconds.
