wow...tankless for $700 !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: wow...tankless for $700 !
    Posted: 07 Dec 2024 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 9:46am
That and DO NOT be standing In the water Stream of a Shower until it has Stabilized!!  Buddy of mine installed one, Almost scalded himself to needing med help.  Still has it but has to turn on water and allow to get stable where runs three to four Minutes Scald and cold then back and forth.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 11:36am
Are they manufacturing nat gas/lp versions? One of the complaints of the early models of the gas fired, was the noise.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 11:40am
My Daughter and Son-in-law have a tankless LPG 'instant' hot water heater. They are off grid so it is their best option, it works well for them. It does make noise, but not unbearable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 11:44am
sounds like a great deal UNTIL you read the installation needs....
THREE 40amp, 240 volt feeds to it !!!
If I turned it on the rest of my entire house would go dark !!!
I looked into switching to a tankless electric water heater but my 200 Amp service is not even close to adequate.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 6:33pm
Something else to consider-many have a recommended annual service which can be a DIY project for those who can.  Otherwise, it's a service call for more $.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 11:05pm
Yes. I recently had to replace my water heater. Asked about going tankless either a NG or electric. My plumbing/heating people flat said NO to either. When asking why they said that my old breaker panel and entrance couldn't handle an electric model and they said hadn't had good extended results with NG or LPG models.
 I've got a new 30 gal NG energy efficient model, more expensive than a conventional NG but cost of operation and rebate from gas supplier will make it cheaper over a few years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 7:57am
the BIG issue with tankless is that YOU have to CLEAN them, often depending on your water quality and most( all) installs to NOT have the bypass plumbing to do it.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 9:49am
I paid my plumber $5600 to bring and install the Navien on demand I wrote about in a recent post. A quick search says I could have ordered the heater "buy it now" for $2400. In addition to that the heater required electric and propane. By getting a separate LP tank we can monitor exact usage and write off the propane to heat a farm shop. A simple line from the house would not qualify because you could not distinguish between the house and shop usage. I've got 4 to 5 times the price of the heater into getting it going.
My wife does telephone sales and marketing. A few years ago she had a coworker miss a bunch of time because they lost power and now/then she wanted a Generac. That represented a huge moment of opportunity, I got a LP tank and had them run a capped off line to the shop for future use while they were running the line to the Generac. The electrician ran the wire and put a breaker box in the new(er) shop while they were there. YES, I 'charged' the wife for all of my add-ons.
The new breaker box and capped off LP line sat unused for 3 years. The tubes in the radiant floor waited 11 years to get hooked up to a water heater. The insurance man did the wood stove in by mandate after Mother Nature ruined all the Ash. It was time.
