Would an Allis make a good rake tractor? |
matador
Topic: Would an Allis make a good rake tractor?Posted: 16 Jun 2020 at 10:08pm |
Over the winter, we picked up an old New Holland #57 rake to help bale the neighbor's straw. For those who don't know New Holland rake numbers, it's a PTO-powered rollabar rake. Last year, we ran the rake with the neighbor's Kubota before we bought it, but he's selling a bunch of stuff this year after the disaster we had out here last year. That leaves us in the spot looking for something cheap to pull the rake with. I've noticed a lot of cheap Allis tractors at auctions. I know the usual third gear problem, but my question deals with the power director. I've never run one outside of our 7040, but I know if you push the clutch in, the PTO stops. How would one go about running a PTO rake with this setup? Would it be a good tractor, or am I better to look for something that isn't orange this time?
The only jobs we'd be doing with this would be the rake, putting in end rows (Anything with a 3 point can do that), and maybe doing some yard stuff with it in the future (Things like a rotary mower and a little blade)
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 16 Jun 2020 at 10:20pm |
I raked hay with a D14 for many years in my younger days with an Allis 78 ground driven hay rake. They are great tractors for raking. The power director is the best invention out there for running PTO driven implements. You can slip the hell out of the thing and it just won't wear out because it runs in oil. 3rd gear problems originate with impatient idiots who repeatedly grind them into gear. My 1958 D14 has been in my family since 1960 and the transmission has never been touched. People hear about the bad ones that jump out of gear, but don't realize there are many others which have never had any problems. |
matador
Posted: 16 Jun 2020 at 10:52pm |
How does the Power Director work on those? I know on our 7040, you don't touch the lever unless you're stopped
Moneypit
Joined: 13 Sep 2018 Location: Barnesville mn Points: 81 |
Posted: 16 Jun 2020 at 10:56pm |
I've got to ask why don't you use the power director unless your stopped?
Dakota Dave
Posted: 17 Jun 2020 at 12:03am |
I've rake a lot of hay with a WD45. Use the hand clutch to stop they are pretty cheep and stone reliable. In my opinion the styled tractor were some of the best looking tractors ever made. For raking I liked the NF tractors. If you put the seat flip hinge on I think mine came from Tony's tractors it corrects the seating position moving it 2" left and back. I wear a sun hat and shades. If you have to get off and on a lot it's a little inconvenient but once on I can drive a long time.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55278 |
Posted: 17 Jun 2020 at 4:40am |
The PD, on the D series is a hi-lo wet clutch, with neutral, in the middle. Stops FWD motion, but not the PTO. Hi is the fwd position, center is N, pull back for LO. You can shift from hi to lo on the fly, or use the PD as a creep clutch, all day, since it runs in oil, as others have said, built for abuse... ![]() You do not use it to shift gears, just go from hi to lo, in the same gear range.
![]() ![]() Edited by DiyDave - 17 Jun 2020 at 4:42am |
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 17 Jun 2020 at 5:23am |
I thought those rakes were 3pt? While a NF Wd 45 with factory power steering is my favorite raking tractor, I don’t think this is what you want. I’d look for a 170-175D or later because they have a very nice 3pt set up or replace your rake with a 256.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 17 Jun 2020 at 5:50am |
Yes it looks like that nice New Holland rake is a 3 point, So it you get a WD series it would need to have a 3 point conversion. The WD series with hand clutch to stop forward motion while PTO was running would be a good fit. They are a little awkward for getting on and off with the implement in place. Maybe a late D17 with the factory 3 point would be the ticket!
Good luck. I see a rake on line like you have for $6500. Regards, Chris
gerkendave
Joined: 08 Jul 2013 Location: York, Nebraska Points: 568 |
Posted: 17 Jun 2020 at 6:52am |
Like everyone else has said a series iv d17 or newer (100 series) would be good as they would have position control for three point so the rake would be at the same level each time you set it down.
The one thing you will find that will be frustrating is when mowing around the yard with an Allis is going from forward to reverse. All of mine will shift from a stop using the hand clutch only. But they all need to be well warmed up and the d14 is kind of tricky, has to be idled down and shifted very quickly. The 17 and my 190xt shift at pto speed no problems from 2/3 to reverse and back easily. It’s a skill you’ll pick up with time in the seat, the biggest thing is remember to not grind the gears and be smooth not jammy when it comes to switching gears with the power director and it can be done. |
allisbred
Posted: 17 Jun 2020 at 8:55am |
I looked at one several years ago and thought it would be useful as well in certain applications, not sure of the weight, figured it should be on a 180-185 tractor although think the 175 would handle it using weights on the front. If used in a bigger operation, maybe a 6080 W/cab would be a nice set up. Just my thoughts.
Edited by allisbred - 17 Jun 2020 at 9:30am |
matador
Posted: 17 Jun 2020 at 9:16am |
Getting on and off shouldn't be a problem- out here, the fields are square and the neighbor's combines are uniform. I hardly ever got off his Kubota.
As for the rake itself, we paid $1000, and that was a bit more than it's probably worth, but when your longtime friend is in trouble and selling stuff to stay afloat, you chin up and buy the rake instead of shopping it around. Besides, we used the rake last year, so we know that it'll work just fine for our needs. We use it to split the windrows in half- our baler can't handle the windrows left by their 30 foot headers. So, with slipping it, the Power Director almost becomes a poor man's hydrostatic kinda, right?
allisbred
Posted: 17 Jun 2020 at 9:24am |
Others will chime in— I was told not to slip a PD years ago, dairy farmer near me said he smoked the PD in his 185 running a haybine in one afternoon slipping it on a 20 acre field. We have ran 185’s (3)PD for over 35 years and never burnt one up. I don’t understand why you would need to slip it running a rake as that only controls ground speed?
Edited by allisbred - 17 Jun 2020 at 9:24am |
john(MI)
Posted: 17 Jun 2020 at 10:19am |
Has raking hay/straw changed at some point over the years? The last time I raked was 1970, back then you didn't need to stop for any reason. A hand clutch, PD was not a necessity. I understand with the introduction of the large balers the windrows are larger, but I would think a D series tractor would work just fine going from hi to lo if heavier hay was encountered. I don't see any reason for slowing or slipping would be necessary. I would recommend you look for a D series tractor. Most of them now have been converted to, or have a 3 point adapter.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 17 Jun 2020 at 10:31am |
D15 is a great rake tractor also
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 17 Jun 2020 at 11:21am |
The D17 Series IV is the first 3pt hitch on any Allis Chalmers tractor that isn't junk, as mentioned earlier it will have a position control as well as better attachment to the tractor and real sway control. Anything smaller or older will leave you dissatisfied when using it for a 3pt rake. The conversions bolt on only to 4 bolt under the tractor and will work loose unless you fabricate extra braces. The 3pt "adapter" is a better option. Although with either the conversion or adapter you will need a set of stabilizer chains to limit how far the hitch will drop.
Beyond that the D-series tractors with the power director are a joy for anything done with the PTO. And who needs a 150 HP tractor for a rake? I pulled a drawbar rake with nothing bigger than a B for years when I was about 6 or 7, it had hand brakes and I was too small to push the clutch and brakes on most of the tractors of the time.
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9436 |
Posted: 17 Jun 2020 at 11:31am |
I just got off a D15 pulling a NH 56 rake. But it's not a 3 point. Is that 57 a Cat I or II hitch? D15 factory is a Cat I. Would think a D17 would do better.
matador
Posted: 17 Jun 2020 at 12:27pm |
Yep- rakes don't take much horsepower. The neighbor's Kubota is 33HP and it handled it just fine, though the front was a little light (Ahhh, modern tractors....). Our 7040 is just too large to be manuverable with this rake. We have a John Deere pull-type rake, but it doesn't handle the volume well at all- the wheel plugs up. I haven't had to stop with the Kubota, but it was a hydro model, so I never really paid attention to speed.
The rake is a Category 1, but the neighbor welded on a bar beneath the factory hitch so you can run it with a Cat 2 if you want to. They used to pull it with everything from an 8N to a 4320 Deere
DiyDave
Posted: 17 Jun 2020 at 5:19pm |
Usedta pul a 256 NH with a Kubota L-185, and that's either 13 or 16 HP, depending on who you believe. Best thing I ever did, for raking, was to use a 3ph drawbar, to pull the rake with. That way you can lift it for transport, or at the ends, so you don't get looped windrows, at the ends...
matador
Posted: 17 Jun 2020 at 6:40pm |
Our other rake is a John Deere 660, so it has a front dolly wheel, meaning no 3 point hack here
![]() This one works nice for the large windrows- the Deere is ground drive, so it just wants to plug at the wheel and not turn the rake. We thought about buying a cheap rake and converting it to hydraulic drive, but then found this rake in the weeds at the neighbor's junkyard. We fixed it up, ran it for the year, and when he announced he was going to have an auction (Which got cancelled due to Coronavirus), we bought it. It's a nice rake, but it's really rough looking. It's one of the really old versions, and it shows. But, it's a rake- there's not much to go wrong with it. If we split his windrows in half with it, our New Holland 276 handles it just fine. For the guy who mentioned a 6080 with a cab, some day, some day.... Right now, we're a one baler operation, so we'll use the 7040 we bought over the winter for that. I would love a 6080 as a second tractor someday, but that in itself would be a really good baling tractor. For just running a rake, while I like his idea, I'm looking at the more "budget friendly" options of pulling this ![]() Heck, who am I kidding? If money was no object, we'd be running two inline balers with 8010's
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 17 Jun 2020 at 8:17pm |
I agree with john..... don't over think it. It's just pulling a rake.
Wink I am a Russian Bot |
allisbred
Posted: 17 Jun 2020 at 8:45pm |
Maybe trade both rakes in for a 500$ NH 56 pull type and save the money you will spend towards a good 3pt tractor and all the cussing hooking up 3pt implements that you can’t maneuver by hand. You will not plug it up.That being said, I have never operated a class 1 3pt implement and a smaller, older tractor with the conversion may be sufficient for your needs. I would make sure it had extendable arms at a minimum though. I personally would not want something 3pt without good depth controls and a heavier tractor without good PS.
Edited by allisbred - 17 Jun 2020 at 8:46pm |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 17 Jun 2020 at 8:46pm |
D series or 6000 series skip the 100 series.
matador
Posted: 18 Jun 2020 at 9:23am |
Hook up shouldn't rally be a problem- once it goes on, it'll stay on all harvest season. As much as 3 point stuff can be a pain to hook up, it's not that bad. The rake handles splitting the windrows really nicely, so it's definitely worth the hookup.
Out of curiosity, what's the reason you mentioned to skip the 100 series tractors? Just not a benefit over the D-series, or is there a problem with them to be aware of?
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 18 Jun 2020 at 3:12pm |
I always raked with a wc. and ac pto rake. ----dont want these big hogs destroying the hay! --- more weight---more damage to the hay. WD-45 or that size would be plenty for just raking and yes they can support 3-pt. hitches---- I have 2 of them with 3-pt on them. Not a fancy tractor but gets the job done. It comes down to you preference in tractors/models. The best tractor I ever used in hay was a IH 560.
allisbred
Posted: 18 Jun 2020 at 3:52pm |
So question back to the OP. Do you need to start and stop tractor movement a lot or the PTO when using this rake? I guess my first thoughts were the advantage of the hydraulic PTO on the 180 and up although not all have that, followed by the weight and 3pt quality & position controls of the series 4 17’s and up. That was just my thinking. We have several 100 series tractors and although the later tractors are nicer, they are still in my mind a cost effective upgrade over earlier ones.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 18 Jun 2020 at 4:06pm |
About the same rake as my new idea rake I pull with my Allis 5020.
matador
Posted: 18 Jun 2020 at 8:35pm |
I can probably do just fine by slowing the throttle down as need-be for a slug. The speed of the rake isn't too important since we're doing straw and not hay. If I can slip the PD if I need to slow or stop for a really big slug, that's all I really need to do. Most of the time, I'd be just moving along like normal. The neighbor's windows are usually pretty consistent, but where they have to stop a combine to pick up the header, you get a slug that you have to crawl through sometimes (But not often)
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1170 |
Posted: 18 Jun 2020 at 9:55pm |
Don't laugh out load to hard. The only tractor I ever raked with was a WC. It did a pretty good job, especially in "teddar" gear..
matador
Posted: 18 Jun 2020 at 9:56pm |
There's no shame in using an older tractor to rake with. I want something that does the job well- I couldn't care less about looks or impressing the neighbors.... or their banker
