Working on Rims and gas tanks
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: Working on Rims and gas tanks
    Posted: 12 Feb 2024 at 10:21pm
Line and painted a couple gas tanks for the I 615 and RL 415.
Also, took the old tires off and clean up rims and put new tires on.
Almost forgot to put a new location for the valve core hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2024 at 10:51pm
Looks great! I bet she will be a showpiece!
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2024 at 11:31pm
How do you make the flat spot in the rim for the new valve stem?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2024 at 8:34am
Nice. Have a few wheel/tire projects to do this year myself. Waiting for warmer weather to do the wire brushing outside!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2024 at 9:16am
I use a torch and heat the area up red, use a piece of wood under the rim to support and a piece of metal as wide the one use to be there and hit with hammer.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2024 at 11:39am
I’ve done that also
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2024 at 12:22pm
When I have a rusted out valve stem hole, I just weld in a washer.
