Working on 180 wiring.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: Working on 180 wiring.
    Posted: 01 Oct 2025 at 8:37pm
The switch has 3 positions.
Low roadway
High roadway
Full field mode
On the rear lights. It has the rear work light and the fender warning light.
Which switch position should the rear work light turn red?
Is the fender light supposed to flash or be on steady? And which switch position should that be ?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 10:24pm
Low and high road should have your tail light and flashers. Field would have your work lights.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 17 minutes ago at 7:00am
Just to expand a little, both yellow lights are flashers. Flashers and tail light should go off when you are in field mode (all lights would be "white" in the field).
Dad's 180 had two yellow flashers (one on each fender) and one rear red light on the left fender.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 46 minutes ago at 8:31pm
Light Switch on 180/185 has 4 positions, (from Operator Man'l) ;
1. OFF, to full left.
2. DIM, outside head lamps (2 lamps each fender) Red tail lamp ON and Amber warning lamp on/flashing.
3. BRIGHT, outside lamp is bright, Red tail lamp ON and Amber warning lamp on/flashing.
4. WORK, all 4 head lamps on, and rear work lamp is on.
 Honestly, I don't remember ever seeing a 100 series with a RED tail lamp.
