work saver three point for wd 45 and |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Topic: work saver three point for wd 45 andPosted: 01 May 2022 at 10:44pm |
anyone have one of those hitches on there tractor
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55290 |
Posted: 02 May 2022 at 4:39am |
I have one of the older ones that had problems with the axle that the lower arms rotated on. I see in the new ones have changed that part to a stronger weldment. Problem was in the outer bracing set up, would break off the outside the arms braces...
HudCo
Posted: 02 May 2022 at 9:06am |
does yours on bolt right on were the adjustable drawbar bolts, and the drawbar is held up with it ? does not appear that these are in stock anymore with anyone so think i will fab one up
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 02 May 2022 at 1:02pm |
have you tried O.K. ? ....... the might have more data..
DiyDave
Posted: 02 May 2022 at 5:06pm |
Yes, and I had to "move" one of the holes, to make it bolt to the DB...
HudCo
Posted: 02 May 2022 at 8:54pm |
with all the ordering i do each day keeping parts here and ones i sell as soon as it says call for avaiblity or low stock it means you aint going to to get it this year or its substituded with some thing like it . but really do not mind welding up my own like in the one picture only with sway blocks instead of the sway arms but its allways nice to start with some pictures or measurements so that a guy doesnt have to spend so much time figuring out all the geomentry so that thing s operate good . lets see some pictures if any one has time for some
Posted: 02 May 2022 at 9:28pm |
worksaver no longer makes 3 point hitch kits... You go to their site and all gone.. but if you sneak in the back door you can find the "obsolete manual" for the WD45 and others.
https://www.worksaver.com/discontinued-product-manuals Edited by steve(ill) - 02 May 2022 at 9:30pm |
HudCo
Posted: 03 May 2022 at 9:24am |
thats what i gathered thats why i am looking for some ones on a tractor "pictures" so i can build my own i like that design the best, not many pictures on the internet
jvin248
Posted: 03 May 2022 at 9:00pm |
. I found someone selling the two lower arms and the upper link from a Ford tractor for a reasonable price. Using ~3/4in+ bolts, nylon lock nuts, and washers I mounted the tractor end of the lower arms to the extra holes for the regular WD tongue hitch bar height adjustment bracket (basically the largest bolts the fit through the existing bracket holes. Regular Class 1 pins are a little larger). I drilled holes in the two lower bars to fit a couple of Kubota three point turn buckles from Tractor supply (although a pair of steel straps with extra holes for height adjustment and pins would work too and save cash). The factory lower arm center holes for the turn buckles was too far forward and the geometry did not work out, hence the extra drilling, get/use a titanium bit). This setup won't work for plowing (no draft/weight transfer bonus) but I can "lift stuff up and put stuff down". ![]() |
HudCo
Posted: 04 May 2022 at 10:03pm |
that looks like a good keep it simple one
