woods mower belts
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: woods mower belts
    Posted: 27 Aug 2019 at 2:01pm
  • I'm sure I've heard it herethat you should only use a true Woods belt,not an imitation if you want it to last. Is this correct? Plenty of aftermarket for 1/2 price but maybe they're really twice the price? What say you. 59 belly under a Super C IH
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 2:08pm
If you don't buy a woods make sure it's a top of the line belt a not a elcheapo
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 2:13pm
A&I sells one made with Kevlar for about half but is it any good? Priced one nearby Woods dealer at $111 plus freight.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 2:31pm
I've had good luck with the "best" from NAPA. About half price. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 4:21pm
I use kevlar belts from V-belts (I think) Have had good luck with them. make sure you get the kevlar ones though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 4:26pm
GOODYEAR and GATES make good belts.... Don't know who makes them for WOODS.. but I doubt they make their own.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 4:40pm
I've bought belts from JDV- belts. They have lasted as long as the woods belts ever did. Just look up the woods part number and they have a belt to fit it. I've tried a generic belt from the farm store and it couldn't handle all the twists. The belting back just came off. I don't rember what I got from JDV but I think it was a gates belt. It dosent matter what belt you put on it must be very tight and aglined properly or won't stay in the pulley correctly. The upper twist pulley needs to be as low in the slot as you can get it. If it doesn't hold the twist you'll ruin a belt in no time. When you get it right a belt lasts a couple years.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 5:50pm
It's hard to beat a Gates belt. We use them on fans in the chicken houses and if we use anything else it'll be replaced before to long. The Gates usual dry rot before they wear out for us
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 8:32am
I have also had good luck with Gates belts.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 8:40am
I too am running a Gates belt on mine after ruining the Woods belt earlier this year. Seems to be holding up fine, was about $60 at Napa. Woods belt is almost three times that!
This page was generated in 1.770 seconds.
