woods mower belts |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8646 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Aug 2019 at 2:01pm |
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10939 |
If you don't buy a woods make sure it's a top of the line belt a not a elcheapo
A&I sells one made with Kevlar for about half but is it any good? Priced one nearby Woods dealer at $111 plus freight.
den/southern illinoi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2071 |
I've had good luck with the "best" from NAPA. About half price. Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
I use kevlar belts from V-belts (I think) Have had good luck with them. make sure you get the kevlar ones though.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88115 |
GOODYEAR and GATES make good belts.... Don't know who makes them for WOODS.. but I doubt they make their own.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
I've bought belts from JDV- belts. They have lasted as long as the woods belts ever did. Just look up the woods part number and they have a belt to fit it. I've tried a generic belt from the farm store and it couldn't handle all the twists. The belting back just came off. I don't rember what I got from JDV but I think it was a gates belt. It dosent matter what belt you put on it must be very tight and aglined properly or won't stay in the pulley correctly. The upper twist pulley needs to be as low in the slot as you can get it. If it doesn't hold the twist you'll ruin a belt in no time. When you get it right a belt lasts a couple years.
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5102 |
It's hard to beat a Gates belt. We use them on fans in the chicken houses and if we use anything else it'll be replaced before to long. The Gates usual dry rot before they wear out for us
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2718 |
I have also had good luck with Gates belts.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4100 |
I too am running a Gates belt on mine after ruining the Woods belt earlier this year. Seems to be holding up fine, was about $60 at Napa. Woods belt is almost three times that!
