Woods L59 mower blade removal |
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Mar 2012 at 7:52pm |
I'm having a heck of a time getting the bolts loose that hold on the blades of a Woods L59 belly mower. Are they reverse or regular thread?
Does anyone have any suggestions on how to break them loose without ruining them, such as a torch?
Thanks.
LannyMTN ![]() Silver Level ![]() Joined: 22 Aug 2010 Location: Middle TN Points: 120 |
They are left hand, or as you call them reverse threads.
Lanny
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Most thing like that and grinder and so on loosen in the direction of rotation.
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
If you're still having problems later, I am coming up on Saturday. I'll call you if you don't PM me back.
allischalmerguy ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
I had a mower that had stuck nut on the blade, we heated it carfully with a torch and it broke loose.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
A six point socket will be your friend. Yes left hand threads. Oh yes and a good impact wrench to put the six point socket on.
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Put a block of wood between the blade tip and the front shield. That is how I do it.
KenBWisc ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1184 |
After you get them loose and before re-installing use never seize on the threads.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If it is an L59, that L stands for left handed because the blades turn counter clockwise as you look down on the deck and it will have left handed threads. I do like Dick suggests, a 6 point impact socket and all ya gotta do is bump the trigger a couple times to remove the blade.
Edited by CTuckerNWIL - 30 Mar 2012 at 10:32am |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
Dick as usual is right on !! Ive taken of blades with a impact that I thot would never come loose having tried a 1/2 in. flex handle with no luck and then they come right off with the impact.
Greg_WJP_(WI) ![]() Silver Level Access ![]() ![]() Joined: 27 Sep 2009 Location: W.Central, WI Points: 250 |
I put a block of wood (4x4), also, and a breaker bar. Fortunately I've never had to pull out the impact tools. And like Ken suggested, some type of anti-sieze is helpful.
Mowersden ![]() Bronze Level ![]() Joined: 20 Oct 2020 Location: USA Points: 1 |
To
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54056 |
Wouldn't that be kinda hard to do, on a tractor mounted mower?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87626 |
Maybe he has photos ?? I have not seen a B or C turned on its SIDE to remove the mower blades..... I WANT PHOTOS !!
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
Miss Mowersden just joined the Forum, then posted. Guess she didn't realize this is the 'Farm Tractor' section. Welcome aboard. |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5226 |
Milwaukee 1/2” impact gun takes them right off. Left hand threads tend to tighten as the mower is used due to the direction the blade turns. Best tool I have purchased in many years. We run our CA up on ramps to get the necessary clearance to remove. L306 is just a bigger version of the L59.
"WRONG" The L59 mower deck commonly used on Allis tractors, has left handed threads, and needs to be turn clockwise, to remove. |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4067 |
Anybody else notice this thread is 8+ years old? OP hasn't checked in since June of this year.
Tuck is correct
![]() Mike, I noticed that because I helped Goose with this WAY BACK. I also noticed that this "Mowersden" was ONLY ON here for 10 minutes and left a link. Is this spam? or is she for real? We'll know the answer if she ever comes back. Edited by Ted J - 21 Oct 2020 at 11:34am |
Methinks mowersden might be a scammer, 8yo post, his first post, don't know what we're talkin about... He's buildin post #'s so's he can hit the site with spam ads...
